Results 1 to 10 of 13
Thread: upgrade done what next ?
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Talking upgrade done what next ?
    well ive done another upgrade today guys !!!!!!!!
    ive taken the airbox intake out and put in a 571i top carbon k&n induction kit in.
    not only does it look good the sound of the air being sucked in when revs hit high and the speed increase is the dogs
    what next i wounder ?
    Regular Member david.aka.judas's Avatar
    Suffolk
    pic added
    Suffolk
    two things seem to be missing the extra cold air feed and the heat shield.
    that thing needs cold air and it needs protecting from the warm air.
    when I had one I ran a pipe from under the car to the filter and I dremmel'd the plastic plate where a spot light would go and ran another pipe.
    worked really well.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    needs a heat shield and cold air feed
    Regular Member djr69uk's Avatar
    Midlands
    or an enclosure with cold air feed?
    Just gave yourself some more work, get to it soon ................
    Apr 2008
    Little Sutton
    Absolutely point less if you ask me..
    No cold air going in.. More noise..
    The air box used cold air - the more cold air the denser the volume - more volume the better air quality going throught the Air Mass Meter - the better the mixture - the better the performance - you would have been better off with the K&N Panel filter..
    Remember the Poly-V belt when wet sprays water everywhere - take a look at the dirty on your bonnet..
    If these were any good VX would fit them to all there cars..
    You would have been better fitting four prong plugs for a better burn..
    Bet you pop your Air Mass Meter...
    Doh!
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    lol, i have a k&n incduction kit almost the same as this, use a vxr intake and got a metal shop to make a heat sheild......and yes, it makes a hell of a difference sound and performance.....ignore the dissbelievers
    Thumbs up interesting read
    well guys i had a k&n panel fitted but this far out ways the performance belive me it moves
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. How to upgrade from sky+ to sky+HD
    By Neil71 in forum General Chat
    Last Post: 8th December 2008, 19:22
