Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: VXR brakes now fitted (pics) and comparison to 314mm kit.
    Default VXR brakes now fitted (pics) and comparison to 314mm kit.
    Following on from this thread, I've now got them all fitted on the car.
    Without further ado, here's they are all fitted...
    Here's the 345mm kit before it was fitted...
    ..and the 314mm kit once removed.
    Here you can see the difference in the disc sizes...
    ..and the difference between the pads...
    345 pads
    314mm pads
    Interestingly, the 345 calipers aro no physically bigger. In fact they are almost identical to the 314 calipers but with a few subtle differences (possibly other differences internally). The carriers are noticeably different - obviously to accommodate the larger discs.
    Also, the pads are overall a very similar size, the 345 being a bit deeper (as in taller) but they have less actual pad surface touching the disc due to the tapered edges on the 345 pads. Obviously with the larger discs there is a greater force due to a greater fulcrum effect, and I'm not sure what specific/significant differences there are in the pad compounds. I hope that there is a marked difference in the power/bite of the kit (not that the 314s were lacking! lol). I'm sure looks are deceiving as on first glance there isn't (visually) a huge difference between them other than the disc size - which obviously itself will make a difference.
    So, how do they compare to the 314s on the road? Well I can't say yet as they still need a good bit of bedding in and initially they don't have the bite of even the 314 kit that's just come off! The system is all nicely bled as the pedal is nice and firm, it's simply they need a decent bit of mileage on them to get them up to full strength - so I'll report back once that's done.
    So, I wonder if i can make your 314 kit fit my rears..........................................
    lol, if there was a way I'd be slapping them on mine to replace the 292s.
    Nice Duncan but I believed the calipers were the same, but I do remember Mark had to adjust the pads to get them to fit.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Very Nice indeed, I bet they fill the wheels up quite nicely
    The Police use them under 17" rims, so there should be a little room to spare...
    Yes, exactly - the 345 pads need some reworking to fit into the 314 calipers just like Mark did. I wasn't expecting them to be bigger, it was more that it was interesting that they are no bigger - if you see what I mean.
    Quote Originally Posted by Big-Pete View Post
    Yep, realised I didn't take a pic of them once the wheels were back on. Will do one tomorrow and post up.
    Quote Originally Posted by Penfold101 View Post
    lol, well as I'm on 18" there's a decent bit of clearance.
    Belfast
    Let me assure you, there is very, very, very little room between the 345mm caliper edge and the inside of the rim on 17's. That's on the standard SVO fit "Elite" 17" rim. There's so little room you have to be careful where the balancing weights go. I'm talking less than 1mm with full pads.
  1. 314mm Brakes Fitted
    By Thomas1 in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2009, 11:56
  2. 314mm brakes fitted!!!
    By amar in forum Handling & Braking
    Last Post: 6th April 2008, 11:10
  3. New 314mm brakes fitted
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2008, 14:47
  4. 314mm brakes fitted
    By trucker in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2007, 13:58
  5. Replies: 11
    Last Post: 25th February 2007, 00:12
93188029
