Thread: slipping clutch
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default slipping clutch
    my clutch is starting to slip a bit in 4th and 5th gear, is this a big money job on the 2.2 dti ,is it a possible diy job , do i just need a clutch kit or both clutch kit and fly wheel any ideas .
    is their such a thing as a solid fly wheel for the 2.2 sri dti ?
    Bristol
    Yes you will need a clutch kit. £339 +Vat. You may find one cheaper on ebay. The subframe has to be dropped to remove gearbox.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I actually thought that the flywheel was solid on DTi ??
    Could be wrong though.
    How can a new clutch by £400 from VX, that is daylight robbery.
    I changed the release bearing in my old 2.0 DTi Vec B and that was about £100 for the part.
    The job is do-able if you have the time, skill, tools and facilities and (if it's anything like the Vec B) not that difficult, just a bit time consuming.
    Not changing the release bearing whilst you're there may be a false economy, as they invariably go soon afterwards.
    If you intend keeping the car, I would say change the clutch, pressure plate and release bearing. If you are thinking of getting shut anytime fairly soon, then I would say just fit a clutch plate. It may even be a good selling point, 'recent clutch replacement'.....
    I am sure there would be cheaper aftermarket sources for the clutch plate rather than VX dealer.
    Bristol
    That is including the realease bearing which is £150. Which if you take gearbox out as it a pig of a job to change clutch.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks for the info lads , ste do you think the 2.2 is solid fly wheel ,is their special tools needed , eurocarparts said £125 +vat for clutch kit .
    if its not that dear a job i will keep the car i took the tuning box out tonight and the clutch isnt slipping now i will keep it out until i get clutch replaced there is 100k miles on the car
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the clutch is only slipping when the tuning box is on (Ie more power), then I suspect that the clutch is on it's way out and it is only a matter of time before it gives way on the normal map.
    What special tool do you mention, what is it's purpose? I've not changed the clutch on any of my recent cars. My Vec B release bearing failure was the last time I had a gearbox off a recent car and i chose not to change the clutch at that time as it was in good condition and I was not keeping the car. Bought the Vec C about 6 months later.
  1. New Clutch Slipping
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 02:56
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Slipping clutch
    Last Post: 23rd December 2008, 19:09
  4. Slipping Clutch
    By kel123 in forum Engine & Drivetrain
    Last Post: 12th July 2008, 11:16
  5. clutch slipping?
    By tonyblade in forum Engine & Drivetrain
    Last Post: 20th February 2007, 19:54
