Results 1 to 10 of 13
Thread: Help, the back ligth and back door not working after using hanger
    Farsund, Norway
    Default Help, the back ligth and back door not working after using hanger
    I Drove my vectra - c 2005 1.9 cdti for about 100 meters with a hanger on and sudenty i got an error message in the display "Please check the rear left blinker" And guess what .
    Blinker dont work, Rear driving ligths are 1 working and the other is lighting on The brake ligth in stead of on the driving light posission, the brake ligth dont ligth when breaking. The back dor on the electric "trunk" (boot) wont open at all, No sound of it trying open at all. and the hanger is dead. tryed another hanger, but now its no ligths at all.
    Checked every fuse in every one of the 3 fuse rooms, and everyone is working.
    And in the room at beside the tire is a "Contact" to the electrical on the hanger, Removed it but it did not help.
    Any one know whats wrong?
    Sorry for my baad english am from norway
    Joakim
    Regular Member Tadpole's Avatar
    'I haven’t lost my marbles, they’re in a bag somewhere? .. '
    Try the search for 'Bulb Warning' there are a few threads with the same issue hth .....
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    What do you mean by "hanger" mate? Tow bar maybe?
    Regular Member sig63's Avatar
    Aug 2006
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    trailer
    I think this one is for kenp
    Farsund, Norway
    Default what i ment about henger is:
    Mileage : 000
    Was your car ok before you put the "trailer" (henger) on the back. Try disconecting the towbar electrics. There should be a plug/connector in the boot somewhere. See if that makes any difference to the working of the lights.
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    joacom -> if many trouble in writing in english.. then just write in native language.. then ill translate
    in danish -> hvis du har mange problemer med at skrive på engelsk.. så bare skriv på dit normale sprog.. så vil jeg oversætte.
    Farsund, Norway
    Default I found the error
    Thank you all for Advices!
    If someone else ever gets this error, ill found the error at fuse 11 in the Rear fuse box.
    kenp: Thanks Wrote under what i did in norwegian, if you find it usefull you can translate it
    Norwegian:
    Feilkilde: Brudd i sikring 11,
    Feil:
    Baklysene ble redirecta til andre lykter, og blink lyset på venstre side virket ikke. kun 1 av 3 bremselys virket. og Bakdøren ville ikke åpne seg.
    Feilen kom etter at jeg hadde kjørt med henger.
    "What i did":
    Gikk først over sikringene med ohm meter, men fant ingen feil, Pusset og vasket over lykteinsatsen på venstre side bak. startet bilen og testet, fortsatt feil, gikk over sikringene med ohm meter (måle resistansen) en gang til og fant feil på sikring nr 11. (25Amp)
    Feb 2008
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Translation:
    Solution, fuse i REC nr. 11 was broken
    Error: Rearlights was diverted into the otherlights, som that only 1 out of 3 breaking lights was working, and reardoor (boot) wouldt open, after been driving with trailer.
    What was done: first tested all the fuses with a "ohm" meter, didnt find any error, washed and polished the headlight (where the bulps go), started the car and tested, still error, went through the fuses againg to messure resistance, found error on Fuse 11 in REC.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So, essentially Fuse position 11 in rear electrical box had blown?
    Sounds like a problem with the wiring of the trailer has blown this fuse.
    Nord, Danish and Russian, all in one day.
    We truly are International..
  1. why are my wipers now working back to front??
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 19:57
  2. yippee ive now got working back brakes!
    By pogo in forum Handling & Braking
    Last Post: 11th April 2008, 22:09
  3. No sound from back door Tweeters
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2007, 22:12
  4. Back window washer not working...
    By Stevie-B in forum Bodywork & Interior
    Last Post: 2nd April 2007, 08:59
