Thread: Help Please.. Door Trim Removal
    asdasd
    Default Help Please.. Door Trim Removal
    Neeed to know how to open Back DOOR CARD..with the window winder not electric...thanks
    Sunny Dartmoor
    asdasd
    Thanks alot helpppppped..exactly what i needed..Thankks
    Sunny Dartmoor
    You're welcome.....
    asdasd
    OK PROBLEM...
    i cannnnnnot get the window turning thing to come offf...tryed and tryed..i dont know how he does it in the pic..putting a cloth in between..HOWWW...i tryed..what do i need to do.. thanks
    Basically it's a circlip mate - you need to bend both ends of the spring away from the catch at the same time, and the idea behind the cloth is to catch one end of the clip with it, and then pull the other end of it with another part of the cloth so that the spring pulls away from the handle without spinning (which it would do if you only pulled on one side...
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    I have used this method time and time again and it come striaght off.....get a metal coat hanger, use a pliers to bend a tiny lip at the end of it, slide it between the winder and the plastic washer (push the door card in), slide the hanger end into the top of the clip and pull it towards you, comes straight off! If you were local, id do it for you!
    asdasd
    DONE IT..finallllyyy..gonna open the rest up tomorw.THANKS ALL FOR YOU HELP..
    used the cloth method..it ripped all the cloth tho..Finally got it done..
    Thanks very muchhhh..
  1. Help please (door trim removal)?
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2011, 23:06
  2. a piller trim removal
    By lloyd_456 in forum General Chat
    Last Post: 1st September 2009, 20:26
  3. Trim removal
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 14:45
  4. Trim Removal
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2005, 23:12
