Thread: FAO anyone who has done there own Dash SMD conversion.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default FAO anyone who has done there own Dash SMD conversion.
    So then chaps, small little beggars these aren't they. I take it you have to get the iron on the flat solder bits on the sides of the SMD as there's no access underneath like a conventional PCD?
    I've arrowed the bits i'm on about in red.
    Bought a kit from CrazyLeds so looking to get started on the header panel tomorrow.
    Regular Member darko2301's Avatar
    Croatia
    yes, that's exactly it
    Oh Mr Rush do take care & good luck .....................
    Croatia
    it would be the easiest if you used tweezers like i did, just catch the led with tweezers on one side and gently touch one end with the iron and then use tweezers to rise that side of the led. then simply place iron on the other side of the led and you're done
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by darko2301 View Post
    Think a new iron might be in order, my tips about the size of the SMD
    Quote Originally Posted by Tadpole View Post
    Dont you worry mate, although Ebay might be getting some money. Ignition on....................BANG!
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Nice one, did you use a solder sucker or just reuse the old solder?
    From the size of those fitting you will require a very fine tip, pity you are not close by. Also a steady hand, I wish you well & should you complete your task a pic will be very welcome ...
    Croatia
    well, AFAIK all tip should be made of copper which means you can sharpen it easily..
    i didnt use the sucker because there is nothing to suck actually
    really, just heat one side and lift it with tweezers, do so with the other and you are done.. i added just a tiny drop of solder when i've removed old SMDs because there wasn't enough to solder new ones
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No worries mate.
    Just the info I wanted, cheers darko
    Croatia
    no probs mate, if you get stuck you know where to ask for help
  1. Dash conversion
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 21:21
  2. Dash conversion
    By irmscher72 in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2011, 21:03
  3. SMD dash conversion
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2011, 19:54
