Thread: Fuel gauge
    Apr 2009
    cheltenham
    Default Fuel gauge
    vectra 3.0 v6 cdti gauge not working??? have put new sender in tank to no avail, garage reckons its bhind the dash problem and its exchange speedo head?? any ideas? supposed to be a common prob
    Regular Member duncan2008's Avatar
    Dewsbury
    mine is always on empty thats for sure! lol
    Glasgow
    They should be able to plug it into there tech-2 and do a gauge sweep which basicly makes all the gauges do a test sweep. If the fuel gauge still does'nt move when they test this then it will be a dash cluster you'll be needing.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What is the input signal from the fuel level sender unit?
    In olden times the sender was simply a variable resistor to ground, so earthing the wire would show full gauge deflection. I don't know if Vecs are the same, or whether the input signal is now more complex.
    If this were the case then it would show if the gauge worked.
  1. Fuel Gauge
    By tatters40 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2013, 14:33
  2. Fuel Gauge
    By don23 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 23:09
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. fuel gauge
    By lob1954 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 19:36
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
