Results 1 to 8 of 8
Thread: help 03 vec playing up
    earlston
    Default help 03 vec playing up
    hi iv just gotten a 1.8 sxi 03 plate and am having some minnor problems
    1st i cant get into the boot by pressing the key or door switches that unlock boot only way to open is by using key in boot
    2nd the rear window wpier and wash do not work
    3rd when i try to indicate either left or right booth back indicators flash at the same time rest of indicators flash as they should just fast as if there was a bulb out.
    so if i turn right for instance the front and side repeeter on the right flash as does the left and right indicator on the back (does same if left but left side indicators)
    have checked all for lose conections bad earth pulled out half my trim making sure cables where ok all appear good
    have checked all fuses with no luck only time it would indicate correctly was very breifly when i turned on the ignition but that was only once.
    anyone shed some light on this as iv run out of ideas
    earlston
    none got a clue on this iv spoke to a few poelple who mention the cim could be at falt what does this do and how would i be able to fix this
    can i get a second hand part or does it need new as iv been told this cim would require some kind of seting up
    Aug 2006
    Is a very naughty boy
    the cim is about 400 quid fitted. Its controls all the steering wheel electronic functions. It could be the problem. A 2nd hand one would need setting up.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    The boot locking mechanism in the pre-facelift Vectra 'C' is the same as in earlier Vauxhall models. Unlike the facelift it has a 'key slot' in the boot lock button. This slot has to be in the HORIZONTAL position for the boot to be unlocked electronically via the remote fob or the door switch. Locking the boot with the key will put the slot ln the VERTICAL position, and if so the boot can only be locked or unlocked using the key. I have just checked this out on my car.
    The thinking behind it is that your boot is vulnerable to theft if your car is locked and your boot isn't, although the boot should auto-lock if not under 'key lock control' shortly after moving off.
    earlston
    thanks replys im getting it put on a tech 2 to see if it can find a fault.
    john iv been leaving the key in the horizontal position electric boot funtions dont work
    also noticed if i put hazards on the rear indicators do not flash rest do so as they should. also no flash when you arm or disarm locks from the keys. could it be a fault from the alarm systems.
    any other thoughts and ill post up tech 2 resultswhen its been done thanks again.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by john_k_sri View Post
    I haven't got a key slot in my boot button....
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Quote Originally Posted by Dan_BlackSRi View Post
    It was dropped on the facelift - cost-cutting! But was standard on the pre-facelift.
    earlston
    well its sorted it after a chance discution at the post office with the post master he mentioned he had a simalar problem with a vectra
    he said to check the hazard switch i thought na shoorly no
    so pulled out the switch and quess what no more problems
    would never have thought that so quick trip to scrappy new switch alls good.
    now iv a new problem my dash instuments now dont work no mph rev temp feul and no ilumiated milage any thoughts on this one lads
  1. Been playing again...
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 20:34
  2. just been playing with my wii!!!!
    By BIG NEIL in forum Games Room
    Last Post: 15th September 2008, 14:24
  3. been playing
    By PeteRs in forum The 'Off Topic' room
    Last Post: 11th February 2008, 15:54
  4. No one playing
    By Steel in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 21:38
