Results 1 to 2 of 2
Thread: after market hu connections?
    Carnoustie
    Default after market hu connections?
    Ok my vec estate came already fitted with a flipout dvd which was powered full time which annoyed me as you needed to switch it off and on a pain!!
    So I removed it as it was not for me anyways, fitted my Blaupunkt mp3 usb headunit and discovered there was no switched 12v feed, so I ran one from the cig lighter, sorted I thought! but now as soon as engine switched off radio goes off, not ideal, what I want is the stereo to stay on until the key is either at the off position or completely removed as was in my vec B
    so the question is can I run a feed from the ignition barrel somewhere or will I need to use the 4volt radio feed to power a relay attached to a 12v feed, any advice welcome
    thanks Ronnie
    Carnoustie
    bump
  1. Ecu Connections
    By viper8 in forum Engine & Drivetrain
    Last Post: 20th August 2011, 17:03
  2. CID connections
    By samarkh in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2009, 17:26
  3. What connections...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 13:33
  4. BSR PPC connections?
    By FiscusFish in forum Diesel Engine related
    Last Post: 30th April 2008, 15:33
  5. PS3 Connections?
    By Stevel in forum Games Room
    Last Post: 9th December 2007, 22:57
