can you put a 2.2 dti turbo on a 2.0 dti??
No, you can't.
Any reason why ? I dont have one, but interested also !!
It's a totally different unit, and has variable vanes and stuff...
Totally different type of turbo. The 2.2 turbo has variable vanes which alter in angle and pitch with RPM and would need a bespoke remap to take account of this. It would physically fit i believe as this has been done on the Vec B sucessfully which uses the same power plant.
Cheers! That sounds quite complex actually!! I dont know muchg about turbos...
Cold air goes in one end, and is compress by compressor blades being spun at ridiculous speeds by a turbine driven by the exhaust gasses. Higher density air enters the cylinders so when compressed by the pistons gives a bigger bang and more OOMPH.
Only way to make a diesel actually go somewhere.............
wow penfold your on the ball toniught
