Results 1 to 10 of 14
Thread: can you put a 2.2 dti turbo on a 2.0 dti??
    Apr 2009
    stockton-on-tees
    Default can you put a 2.2 dti turbo on a 2.0 dti??
    Belfast
    No, you can't.
    Wales, UK
    Any reason why ? I dont have one, but interested also !!
    It's a totally different unit, and has variable vanes and stuff...
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    Totally different type of turbo. The 2.2 turbo has variable vanes which alter in angle and pitch with RPM and would need a bespoke remap to take account of this. It would physically fit i believe as this has been done on the Vec B sucessfully which uses the same power plant.
    Wales, UK
    Cheers! That sounds quite complex actually!! I dont know muchg about turbos...
    Cold air goes in one end, and is compress by compressor blades being spun at ridiculous speeds by a turbine driven by the exhaust gasses. Higher density air enters the cylinders so when compressed by the pistons gives a bigger bang and more OOMPH.
    Only way to make a diesel actually go somewhere.............
    Regular Member mattolly86's Avatar
    oxfordshire
    wow penfold your on the ball toniught
    Quote Originally Posted by mattolly86 View Post
    I'm in full geek mode...
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
difference between 2.0 dti and 2.2 dti
hybrid turbo for dti vectra b
does the 2. turbo fit the 2.2 dti vectra
does the 2.2 turbo fit the 2 dti vectra
difference between zafira 2.0dti and 2.2dti
Vauxhall 2.2 variable vane turbo
different between 2.0 and 2.2 opel vectra B
turbo zafira 2.2 dti
2.0 dti with 2.2 turbo
can you fit the 2.2dti turbo on a 2.0dti vectra c
differences between 2.0 dti and 2.2 dti
2.0 dti turbo
2.2 dti to 2.0 turbo
vectra b 2.0 dti turbo range
