Thread: HID Problem
    Oxford
    Default HID Problem
    I'm in the middle of fitting my HIDS and there not working properly.
    I tested them first to see if they worked and they did fitted them and now when i turn the lights on they come on but only for a split second and then turn themselfs off?
    Any ideas?
    Cheers Matt
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    are the wires the correct way around?
    Oxford
    yes as if it swap them round they dont come on at all
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    you tried removing the cancelers?
    Oxford
    didnt come with any Jam-Performance said they were in the ballast.
    one was just working again a min ago now its not again getting frustrated now
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    did you wire them in the right way first time?could be dodgey ballasts but both doing the same?...a bit strange how both arnt working tho
    Oxford
    yeah wired them up fine they can only really go one way. 1 Bulb doesent light up at all so swapped bulbs and only the middle of it lights up for a split second then turns off.
    Oxford
    Just gone to emailjam performance and it says there no longer a registered ebay member?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Try there mobile
    "We are moving Shops on ebay, to contact us further please call 07931 131 237 or mail us. The new shop will be in service from the 6th March 2009. Thanks again2
    http://myworld.ebay.co.uk/j_a_m_performance
    Oxford
    I have narrowed it down to only 1 Bulb and 1 Ballast works. If i fit the working bulb in the Ballast i believe is broke it only lights up the middle of it for about 2 seconds then turns off. But works fine in the working Ballast. Then if i put the bulb i believe to be faultly in the Ballast that works on the other Bulb it does not work. All the wires are right as when the none faulty Bulb and Ballast are connected they work fine.
    CHeers for that Info Bigmac i have emailed them as no one is answering.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
