Thread: Driver side window rubber pushed up....
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Driver side window rubber pushed up....
    Hi all.
    I've a ****** of a problem with my front drivers side door. The window rubber has pushed up out of position. As well as looking naf, its putting a little extra pressure on the window as it lowers and rises. I'm afriad that this might cause future problems with the motor etc.
    Has anyone else had this problem.
    My plan is to take off the door card (painful) and try and re-set the rubber back into the normal position. I'll get some pics on when the weather is nice!
    Mar 2007
    NI
    Picture as promised.... No one had this problem?
    WGAF#5
    door card off would be the best repair - the motor wouldnt be under any additional strain -if it were the "ant pinch" should cut in if there is too much resistance on the motor
    door card took me 10 minutes to take off and 15 minutes to realign and get back on when i changed my door check strap - first attempt to refit i had the same result as the picture you posted
    Mar 2007
    NI
    Might not be worth the time of effort then.... its just that it looks a little naf. Nevermind.
  1. Driver side window and mirror not working
    By j2cams in forum Bodywork & Interior
    Last Post: 3rd April 2011, 21:51
  2. Driver side electric window stopped working
    Last Post: 18th March 2011, 01:16
  3. Driver side electric window stopped working
    By danlat1415 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2009, 23:05
  4. Rubber seal on the front window...
    By Stevie-B in forum Bodywork & Interior
    Last Post: 13th May 2008, 14:37
