Thread: Lowering advice
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Lowering advice
    Have spent the last couple of months trying to decide what route to go down with regards lowering The V6 CDTI. I had decided on Coilovers but only so ic ould adjust them. My only reason for this was because a couple of times a year i load the car up fully and drive to Italy so wanted to be able to lift the rear to make up for the additional weight. I was wondering though what difference lowering the car with a set of Eibach's would make to the load i could carry. Any number of people suggest that Eibach's teamed with Bilstein's will give me better handling the the coilovers.
    So basically what i need to know is what effect on my carrying ability will the eibach \ Bilstein have.
    Also does any one know which Eibachs i would need for teh v6 CDTI?
    As always thank you in advance for all your help and advice.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    how low are you wanting your motor to go?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Currently running 18's on 225/40/r18 tyres. Is sri spec so 15mm lower already. Was thinking minimum of 45mm drop springs so 30mm lower then currently. Although any advice welcome
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by s_zigmond View Post
    you will see mine at 1pm then you can decide for yourself
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by bobby-tupper View Post
    Sorry mate hadnt apreciated it was you that had posted on here
    Really should look at who replys to my threads.
    Was good to meet you and cheers for dropping them off.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    didnt the name give it away?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    If i had looked at the name it would
    I was posting while trying to look busy so hadnt read who had replied.
    Cheers again
  1. advice on lowering
    By byers in forum Handling & Braking
    Last Post: 6th December 2011, 12:03
  2. lowering advice
    By denzilbud in forum Handling & Braking
    Last Post: 20th April 2010, 12:48
  3. car lowering advice
    By darko2301 in forum Handling & Braking
    Last Post: 3rd June 2009, 00:08
  4. lowering advice
    By platinumpete in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 21:35
  5. Need advice on Lowering
    By bizerk in forum Handling & Braking
    Last Post: 15th September 2008, 18:33
