Results 1 to 10 of 16
Thread: Should I????
    Regular Member signum junkie's Avatar
    Edinburgh
    Default Should I????
    Had the car in for a service today (£106) and came back with news both rear springs have broken and rear suspension control arms have excessive play.
    The positive spin is I can now get it lowered without the missus objecting so was giong to order all parts from LMF consisting of Spax springs all round and control arms .The question is should I replace the rear shocks with bilstien b4's at the same time while the garage has it apart or wait until the standard ones go (how long should standard ones last? My millage is 57k at mo)
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the shocks should not be near gone now.. (but we never know), but i would probaly have them changed now they where fidling with it..
    cheap service i must say (maby common price in scotland), my garage woulnt have let me drive with those faults..
    Luxembourg
    Eibach Eibach Eibach mate
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    They are worth the extra if you can spare it mate
    Edinburgh
    cheap service i must say (maby common price in scotland), my garage woulnt have let me drive with those faults..[/quote]
    The guys do all the work at very good price and said it is safe to drive as it is bottom coils that are broken and control arms are no biggy(apart from the noise) for driving round town. As the said m8 at least this way i get to make the desision on what springs I use and find at best price. They are quoting between £100 and £140 for rest of work and labour (tidying slight corrosion on brake line and sealing, fixing play in steering and fitting all parts i source)which i dont think is to bad .
    Edinburgh
    Quote Originally Posted by Fly View Post
    Only £40 diff but lower all round 30mm as apposed to 25mm back and 35mm front on Spax
    You may be right I think I read a thread somewhere on eibach springs and bilstiens being a good combo
    Regular Member j13hdb's Avatar
    Nottingham
    If they're paying under warranty or just charging a fixed price get the best you can cause it involves no more work ie eibach or bilstein and could be a couple of years before you can deceive the wife again! Your not changing shockers though if they're ok? It's the springs that will drop it!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Edinburgh
    Thats the one m8 but is it worth changing just the rear shocks as I couldn't afford the fronts as well
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Wouldn't affect anything in a bad way. I assume it's B4's you are going for. You could do the fronts later if you wanted to
