Thread: Twanging Noise
    Blantyre
    Default Twanging Noise
    Getting a twanging noise from the front near side, usually when its on full lock, turning left when i pull out the drive, any ideas what it is , Car is due its first MOT Tuesday
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Quote Originally Posted by spennny View Post
    I have the same problem mate, only started after new springs were fitted (Yes, they do have the rubber bit on them!), it sometimes sounds like a grating noise though...but only when turning left and accelerating
    Regular Member barkzz's Avatar
    Normally the "twang" is due to the spring twisting in its seat.
    This is the metallic sound you hear, at full lock, or going over undue terrain. On mine this persisted for some time, before i finally seen pieced of the spring go bouncing down the road.
    Get them to get it up on the ramp, and give the twanging spring, a cud twist and turn, if the noise is replicated, your spring is probably on the way out.
    Failing that, the disc brake, back plains could be catching when you turning at full lock angles. This has also happened, and is just a simple case of a minor 2 second adjustment.
    Blantyre
    Quote Originally Posted by barkzz View Post
    Thanks for the info mate, will check the springs tomorrow along with the brake back plains, have a feeling could be that as the brakes were done last month , and has started roughly from that
  1. Replies: 4
    Last Post: 25th June 2012, 22:40
  2. Twanging suspension when turning
    By Mogsy007 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2010, 14:28
  3. 'Twanging' noise from front right??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 21:00
  4. twanging front springs
    By DARREN R in forum Handling & Braking
    Last Post: 9th July 2009, 11:12
  5. Handbrake twanging noise
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2009, 09:44
twanging noise when braking
