Thread: A tip!
    Wiltshire
    Default A tip!
    Never, ever, ever mix this with this!!
    I must have had a bit of the Zymol stuff left in the foamer part of my pressure washer and stuck some of the other stuff in coz it was all I had in the garage at the time. They don't get on at all well! Mixed, they turn into a green glue-like substance that sticks to everything it touches. I've washed and washed my hands so that the've gone all wrinkly and they still feel sticky. I also had to go over the whole car with tar remover to get all the sticky bits off. My Kärcher foam gun is soaking in boiling water, but I may have to buy another.
    YUK!!
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    mostly down to the flash shampoo me thinks - I've used this in a bucket once for the same reasons - all I had kicking around - and it made more problems than it solved - I think it needs to be really diluted to use in the Flash gun.
    Feb 2006
    Guttedsville
    At least you can use your hosepipes!!
    Hertfordshire
    Quote Originally Posted by Andrew's SRi
    Don't get me started !!!
