Thread: sludge and a smell of petrol
    herts
    Default sludge and a smell of petrol
    As i was bored on Monday thought I'd pop out to the car and have a potter around her, cleaned the alloys, hoover all going well until i thought i would check the oil.
    When i 1st took out dip stick there was a mustard colour on it after wiping it a dipping it a few times this seemed to go (but not entirely) but there was a strong smell of petrol coming from the dip stick but when i stuck my nose into the oil filler there wasn't a smell there the car is due for a service and i have only owned the car for a year (exactly) can anyone help
    Also what is the best type of oil to use .. i have a 2.2 sri 2002
    Regular Member barkzz's Avatar
    best oil 5W30 Fully synthetic.
    Not sure over the other issue you describe, does it look like mayyonaise? Normally the head gasket, as water with have mixed with the oil
    Glasgow
    If you use it for small stop start journeys this could also be the problem it wont burn off condensation inside the engine, change the oil and filter and take it out for a long drive every now and then to give it a good heat up.
    Regular Member djr69uk's Avatar
    Midlands
    sounds like head gasket symptons to me fella. sludge or mayo is the water mixing with the oil. the only way petrol can get into the oil is head gasket failure...
    to be certain you can get a compression test done. you might also be able to smell petrol in the coolant tank. a garage can 'sniff' this for you using a gasket that will tell you if the coolant is contaminated with petrol.
    other signs are dropped coolant and oil levels.
    herts
    thanks to you all for getting back...no oil or water mix checked that someone said seals might have gone but its in for a mot and service next week so will defo get a oil and filter change and give it what it deserves a nice long boot down the a10 also drives fine no missing and temp stays at just below 90 its done 63k nice one barkzz for the oil tip
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by byebyeitsagsi View Post
    I would say your right there mate mines always on long runs never had this problem only when short journeys does it start doing such things
    Quote Originally Posted by djr69uk View Post
    As above could possibly just be condensation take it for a good run then check
    WGAF#5
    thought the filler neck issue was only on 3.2 v6's ???
    everything else has the shorter neck so this shouldnt be the cause?
    herts
    cheers guys you are right only do short journeys do 3x10mile journeys a day and thats at 30-40 will be giving it a good boot every now and then
  1. smell of petrol
    By Tam80 in forum Engine & Drivetrain
    Last Post: 16th September 2010, 22:10
  2. Petrol Smell
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:20
  3. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  4. petrol smell
    Last Post: 22nd November 2007, 19:40
  5. smell of petrol
    By kevinmcm19 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2007, 23:16
