Results 1 to 10 of 23
Thread: MOT Fail........advice please
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default MOT Fail........advice please
    Car failed its MOT today on the following..........
    Offside headlamp main beam bulb
    Offside front coil spring cracked
    Front discs excessively pitted
    Ive got new discs and pads,bulb isnt a problem but what about the spring?
    do you change both of them? Is it DIY'able? where is the best place to get springs? Lastly should I do the shocks at the same time?
    Car is a 2004 Vectra 2.2 direct with approx 62K miles
    Cambridgeshire
    Change both the front springs mate. I wouldn't change the shocks unless you need to. If the MOT didn't mention them i'd leave them be
    HTH's mate, good luck
    Sunny Dartmoor
    You should replaced springs in pairs John,there is a How2,but if your not confident enough then get a garage to do it for you,best place to get them,i'd say any decent motor factors or ebay if you don't mind waiting,good luck m8 and let us know how you get on,hth........
    Apr 2006
    Inverclyde
    Cheers.Just need to hold on to the car at the moment as it is paid for and I am being made redundant at the end of the year (if only I wasnt..........) so I have to maintain it the best I can
    Is the Dealer the best place for the springs (I have a Trade card) or is there a better alternative?
    Regular Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    as said above, only ever replace springs in pairs.
    make sure you get the correct springs too. They are colour coded with a series of coloured dots about 10mm in diameter each.
    Dont change shocks, no need to if nothing has been said about them.
    about doing it yourself. I can't stress enough how dangerous it is when changing front springs. if you are not competant enough or dont have the correct tools, Dont even attempt it! I've had front spring fly out of a compression tool once when it was fairly compressed. And was using a decent tool correctly....... Fortunately all it did was dent our tyre machine at work, but could have been a hole lot worse!
    as for where to get the work done. A dealer is a decent place to choose but a pair of front springs is usually allotted a fair bit of time on the books. basically you may end up paying quite a bit of labour costs for the job. A well known independant garage would be much cheaper
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    chances are you will only get the springs from a dealer as you have an sri
    May 2006
    scotland
    Does Kwik-Fit or the likes not fit springs now?
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    most garages can fit springs,i would avoid kwik-fit though
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    for the cost of OE springs, i would get a lowering kit
    Sunny Dartmoor
  1. Would any of them fail MOT??
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2012, 19:11
  2. Mot fail...
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 21:16
  3. Fail
    By Ste in forum The 'Off Topic' room
    Last Post: 2nd March 2010, 23:06
  4. Mot Fail
    By Cam in forum Engine & Drivetrain
    Last Post: 8th February 2010, 23:11
  5. MOT Fail........advice please
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 18:18
