Thread: Exhaust Question?
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Question Exhaust Question?
    Coming from the world of petrol engines and knowing that exhausts are part of tuning related to the engine. I notice that some on here are upgrading from 1 exit to 2 exits on the CDTi 120/150 using 2.2 back boxes.
    My question is, does is matter what you do to a diesel exhaust? Are they not sensitive to change in back pressure or is it nor an issue?
    cambs
    hi
    it doesn't matter which car the exhaust comes from as long as the bore of the exhaust is the same or greater then the original.
    you will not have any back pressure problems m8
    Leicester
    Diesels do not benefit from exhaust changes like petrol cars do.
    The main reason that owners are going from single to dual is because they look better with one each side.
    By going down the dual route, you may see a little increase in power as the engine can get the gas's out quicker, but you will see a small drop in bottom end torque as the back pressure is slightly reduced.
    I proved this on back to back rolling road runs, before and after.
    Cambridgeshire
    really mate.
    I did mine for the looks. I'm sure you would get more gains from a diesel if you removed the exhaust completely
  1. Exhaust question.......
    By adamtaylor in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 23:24
  2. Exhaust Question
    By RichieSRi in forum Tuning
    Last Post: 24th January 2011, 10:29
  3. Another exhaust question
    By MattW74 in forum Petrol Engine related
    Last Post: 28th July 2010, 09:43
  4. exhaust question
    By andy_hare in forum Engine & Drivetrain
    Last Post: 9th April 2010, 15:06
  5. Exhaust Question....
    By joules2.0t in forum Petrol Engine related
    Last Post: 27th March 2007, 20:07
