Thread: different tyre sizes
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default different tyre sizes
    i bought a second hand set of 17 inch alloys 2 wheels with 225 45 17 and 2 with 215 50 17 could i put these on my car, would these different tyre sizes make any difference.
    Leicester
    The 215 50 17 is the standard tyre for Vectra C 17" wheels, and 225 45 17" are a european fitment for Vectra, so is also OK.
    But it is not advised to fit both sizes to one car.
    The Vectra C has different tyre size groups that can be programmed using Tech 2.
    205 55 16", 215 50 17, 225 45 18" and 235 35 19" are in one group and 225 45 17" is in another.
    If you fit 225 45 17" all round, you can change the tyre group on tech 2, as this will ensure the speedo is correct.
    Having different rolling radius on the front to back 'could' turn on the ABS light as the ABS will sense different speeds from the front and rear.
    So if you
    Full Member Big Sig's Avatar
    The above is not 100% true. You can fit them but make sure the sizes stay the same on each axle. i.e 225's on the front and the 215's on the rear. NOT one on each axle, DO NOT mix and match on the axle
    It will not put the abs light on as I ran mine like that for a year when changing sizes with NO problems what so ever
    (also imo no real need for the tech 2 as there is so little difference in size. Just a waste of money unless you can get it done for free)
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by Maverick View Post
    So if you
    I've had 215's on the front and 225's on the rear for a year now without any problem whatsoever. To mix sizes on the same axle is not advisable but having a mix of the two sizes (one on each axle) is perfectly alright and legal. I will be replacing my 215's with 225's when they need replacing, so I will have 225's all round in due course.
    May 2016
    UK
    Vehicle : Vextra
    Trim : SRI 2.0 TURBO
    Engine : 2.0 turbo
    I currently have these alloys they have the standard 215/50/17 tyres on, can i fit 225/45/17 tyres on them?
    As i'm looking for abit more grip and slightly harder ride.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes you can.
    May 2016
    UK
    Vehicle : Vextra
    Engine : 2.0 turbo
    Thats great will get a set on there asap thanks
  1. Which tyre sizes
    Last Post: 5th October 2012, 00:42
  2. Tyre Sizes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2011, 19:29
  3. tyre sizes
    By mrpatterson2008 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 17:50
  4. tyre sizes
    By chrissri82 in forum Handling & Braking
    Last Post: 4th June 2009, 12:59
  5. Tyre Sizes
    By Pendo in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2006, 23:02
vectra c tyre size
tyre size vauxhall vectra sri diesel
correct tyre size 2005 vectra 1.9 diesel
vectra c tyre size sri
vectra sri c tyre size
vectra 17 tyre size
vecta c tyre size
vectra c tire size
tyre sizes for vauxhall vectra 1.8 sri 2005
standard fitted tryes to vectra c easte
opel vectra tyre size
vectra Sri cdti tires
vectra c wheel size
vectra c alloy size
elite tyre group
vectra c 17 tyres
vauxhall vectra c tyre size
opel vectra c tyre size
tyre size 2255517 for Opel vectra c 2004
what size tyres on vectra c
vauxhall vectra tyres size
vectra 2.0 turbo tyre size
vectra c 16 tyre size
vectra tyre size for 1.8 estate
vectra c gsi correct tyre size
