Thread: 3rd injector problem
    wylam
    Default 3rd injector problem
    having read some threads on here im thinking does my car have this problem.its a 08 vec cdti 150 sri.when cold it smokes a bit too much it ticks over lumpy if you rev the engine the whole car vibrates and if you pull away it feels like its mis-firing but once it warms up it feels ok.it sounds like other members here are having probs with 04-06 models but like ive said mine is a 08
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    get it to the stealers m8 warranty m8tey
    May 2006
    scotland
    Quote Originally Posted by smurfy View Post
    Mines a 04 150 CDTi and has done this pretty much from 10k miles when I bought it 3 years ago. Never became any worse in that time. Mine is a bit lumpy when cold, like a slight misfire but car generally does not vibrate although I am away of a slight misfire.
    Feb 2007
    North west
    08 plate have a modified loom, came in about 06 IIRC so no danger. Smoking from cold is normal - I dont know how much obviously. Lumpy from cold sounds more like a dirty EGR valve. Does it pick up ok from about 3K revs ? Very sluggish from cold ? If so look at cleaning EGR valve with some Wynns card & inlet cleaner. I would have guessed you'd need at least 12,000 miles with a tuning box or 20,000 + without one to have sooted up an EGR however. If your mileage is low doubt its the EGR unless you do seriously short trips on poor quality fuels.
    wylam
    my car just turned 20k,its going to stealers this Thursday night so they can start it from cold on Friday morning.
  1. Injector Problem
    By vectra19 in forum General Motoring Chat
    Last Post: 8th June 2012, 23:40
  2. 150 injector problem
    By lee640 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 21:13
  3. Injector problem
    By Deano.56 in forum Engine & Drivetrain
    Last Post: 29th July 2009, 13:58
  4. 20 dti injector pump problem
    By stevie b in forum Engine & Drivetrain
    Last Post: 20th March 2009, 20:55
  5. EGR or INJECTOR PROBLEM
    By dingle in forum Engine & Drivetrain
    Last Post: 18th May 2008, 16:56
