Results 1 to 10 of 11
Thread: Speedo / Rev counter etc
    Yorkshire
    Default Speedo / Rev counter etc
    I have noticed that some Vec C's have chrome rings around the dials etc on the Speedo instruments.
    Are they coded to the ecu / car etc?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    No but mileage is recorded on speedo and in ECU/CHIP iirc
    You can buy one from ebay or such like and as long as you get the correct top speed/revs as some are different you should be able to swap them without any problems
    All though you will have to get a digital mileage correction company to adjust the readings from milage stored in car and on new speedo this is around £100 mark HTH
    Leicester
    The instrument panel is paired with the car with it's security code.
    You will need to 'divorce' the instrument panel from the donar car with tech 2 or it will not work in your own car.
    Also pre-facelift cars will not be compatible with the later canbus cars from facelift onwards.
    Regular Member zazaszazas's Avatar
    Cumbria
    Quote Originally Posted by Maverick View Post
    well i've changed my standard preface speedo 52reg for a gsi chromed one and everythings work fine.no tech2 just straight swap they were
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not meaning to sound funny but how do you make out they are tech2 to car ? i was on the understanding that they are a straight swap (as i have all so fitted sri clocks to mine with no problems what so ever) i just have to pay to get mileage sorted out.
    And your right about preface and facelift speedo's you cant fit a facelift into a preface and vice verse due to there being no small window in rev counter on facelift speedo's
    cambs
    Quote Originally Posted by bigmac View Post
    hi
    they are tech2,d to the car but will swap over and you will loose some functions seatbelt warning, next service due and you cant get them to work unless its been tech2'd out of the original car.
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My bad i thought it would all work as mine does
    cambs
    I only found out when went to the dealers and tried to get the functions that didn't work turned on.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    they are a straight swop ..you will loose some fuctions ..but the time to worry is when you come to replace another control unit the imobo system wouldnt like them and you would need to replace them with a new unit after all unless the car is useless...............
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    humm hans_vledder changed his, got the counter put to correct milage. and afterwards went to the stealers, and had some stuff disabled via tech2. hi didnt loose any thing.
    So if they are saying its coded (locked to the car). they are full of ********.. it can be changed if they want to.. but always easy just to say its locked.. in hope of selling new one..
    the fun part go to a stealer to say thats there a malfunktions that it has dropped a bit.. (dont say you change the speedo) then they funny enouhg can code it..
  1. LED Conversions on Speedo and Rev Counter Pics?
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 15:47
  2. rev counter, speedo problem
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2011, 21:41
  3. interchangable dials (speedo/rpm counter)
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 16:57
  4. speedo and rev counter eratic
    By johnrolfe in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2008, 19:22
  5. Dead speedo and rev counter
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 00:18
vectra c canbus speedo
