Results 1 to 10 of 11
Thread: Engine Issues? 1.9 CDTi
    Regular Member Ean's Avatar
    Suffolk
    confused Engine Issues? 1.9 CDTi
    Morning All,
    We are getting a VX 1.9 CDTi 120 HP.
    Elite spec, etc....
    Just wondered if therre is anything we should be looking at? Engine troubles?
    Recalls that shouldve been done? are they reliable?
    Car has 40,000 miles.
    Any help and advice, will be groovy baby!
    Cheers,
    Ian
    Regular Member barkzz's Avatar
    Main issues i've heard of, but effecting the 150 cdti more commonly are:
    EGR Valve
    Swirl Valve
    Dual Mass Flywheel
    Problems with the inlet manifold, affecting the Turbo
    3rd Injector Wiring
    Apparently the issues are more prevailent on the 150, than the 120.
    I'd say make sure it has got a decent service history, and if you have any doubts, make sure you highlight them, before purchasing.
    Only recall that i can think of is for the handbrake modification, to stop your car from rolling away!
    Regular Member renodci's Avatar
    Kent
    I learnt yesterday (from a differnt thread on here) that the 120 doesn't have swirl valves - so that potential issue can be removed from the list . Also, apparently the EGR isn't as problematic on the 120.
    Suffolk
    Dual Mass Flywheel
    3rd Injector Wiring
    Are those bits expensive?
    Quote Originally Posted by Ean View Post
    Dual Mass Flywheel
    3rd Injector Wiring
    Yes they are, not sure on exact costs, as ive only had my sri 150 3 weeks.
    I think the DMF is about £800 with fitting, and inlet issues arent cheap. £900ish????
    If the turbo gets shafted, that's expensive. Not sure on injector wiring.
    As i said previously, make sure the service history is up to scratch, but from what ive read the 120 is certainly the safer bet.
    preston
    Ive got a 120 (purchased 8 months ago now 100k on clock) and just changed glow plugs as spanner light came on.
    Looks like mine has had a new alternator recently (before i bought the car) so these must fail, something to watch out for.
    Mine has an occasional misfire which I believe is down to 3rd injector plug wiring, easy diy job.
    If you intend to change the oil and filters yourself get yourself a new sump plug as they shear easily.
    My dmf has started making a noise when clutch pedal depressed so another big job coming up for me.
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    Quote Originally Posted by bygumlad View Post
    think mine has the 3rd injector wiring fault do you know what problem i would be seeing m8 thx
    Suffolk
    So....is the conclusion, go for the 1.7 Izuzu Engine?
    preston
    What 1.7 isuzu engine?
    preston
    tankman,
    The problem you would be seeing is just the odd misfire, it seems to happen when the engine is very hot , hotter than normal running temp' i.e. after stood in traffic for a while then setting off when the engine is labouring particularly in second or third gear. No engine management light and car runs just as normal. to help keep temperatures down around the injector area, I have removed the plastic engine cover and left it off
  1. Replies: 200
    Last Post: 16th November 2015, 09:23
  2. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  3. I need to clean my engine/bay without electrical issues.How?.
    By felixx in forum Detailing and Car Care Discussion
    Last Post: 19th July 2010, 08:40
  4. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  5. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
