Thread: CD70 GPS single problem - Update :(
    VIP-Member MCD's Avatar
    NE Manchester
    28 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default CD70 GPS single problem - Update :(
    Hi guys,
    Well, i think it must be a fault with the headunit. Ive tried the aerial which came with it in front and rear windows, and now a brand new aerial in same position.
    Sometimes it gets signal instant, sometimes it just wont get signal unless i eject the CD and re insert. But ive found even this doesnt always work.
    The only 100% sure way of signal quickly or instantly is to eject CD, turn of unit. Listen for CD mech or whatever it is to wur into a position?? Wait 10 secs and then turn back on. This gets signal almost instantly even without CD in.
    The last two nights, ive left the CD out all night, and when come to car in morning, it doesnt take long atall to get GPD, maybe 20sec at most. Then i put the CD in, and it works fine.
    What i have noticed is, when i unlock car and get in, i can hear bottom CD drive wuring slightly, even before i turn ignition and unit on... is this normal?
    Off course this is a right pain in the arse! Any more ideas please guys? Or, is there a techy guru you can recommend to have a look at it please??
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/XP2'd
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Quote Originally Posted by MCD View Post
    Sorry to hear your still having problems mate.
    It is normal for the CD to start spinning as soon as you open the door. HTH
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    yes
    ... and I wonder if this is the cause of your problem: the moment you open the door, the satnav tries to find the location of the car, but perhaps your aerial has no power at that moment... when you insert the disc, it reinitializes again; so I understand that when you do this with ignition on, everything goes fine
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Hi guys,
    Mike
    Mike 101% wasn't a fault with the unit when it was in my car
    For sure it worked every time it was switched on.
    Why you're still having issues I dont know. Assuming you have the aerial n nav aerial plugged in the right holes lol ?
    Can't see it being an area thing, so can only put it down the the aerial itself?
    Not sure but I assume the O.E proper nav aerial is powered, whereas those you are using aren't?
    Can anyone confirm that?
    Could that cause the probs you are having?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    The O.E aerials are powered its a signal booster so might make a difference,best bet would be to get hold of a O.E aerial and try it before shelling out on some one looking at HU
    You will need to find a donor car and remove aerial lead this plugs into a connector on drivers side footwell down by bonnet release,then unplug other lead and trace it back and remove from loom if you get stuck pm me i know where theres a 06 navi and it might have the wiring still there for aerial but not the aerial as i have it sitting next to my computer
    Surrey
    You can get the extension lead from Ebay. Perhaps see how much they are at the dealer, you never know.
    NE Manchester
    28 Post(s)
    Engine : z20net
    Mileage : 80k
    Well,
    Been on holiday around Devon for 10 days. The physical NAV worked a treat, and often flagged up traffic alerts, and helped re-route me!
    But!! Still, its a sod to get signal first thing! Every morning i had to either turn on and wait 2 mins, or switch on & off, or eject CD etc....
    I guess i will just have to live with it! Its not the end of the world as i can always get it to work, just its not always automatic! I cant see why i need to upgrade to OE aerial though? As alot of you guys have gone aftermarket with the CD70 and aftermarket aerial no problem, i fear my issue is simpky the head unit
    Cheers for help!
    Mike
    Regular Member Phil MC's Avatar
    Kirkie
    I'm going aftermarket with my aerial for my Nav70, but I made sure it was a GPS aerial with the coax connector and a power connector for the built in signal amplifier .
    Sounds like this could still be your problem if using non-amplified aerial.
    A simple gain of 3dB is equal to doubling your signal strength, and my new aerial has a signal gain of 12dB!!!!
    I just need to know how easy it is to change the Navi aerial and how to go about doing it so I don't trash my roof/ceiling interior trim???
    Cheers,
    Phil
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Are you changing your OEM Aeriel Phil ? if so its easy to change i would remove grab handles on drivers rear and pull seal away from door and top rear boot then pull headlining down,you will see the aeriel its bolted on with a 17mm bolt remove plugs and undo bolt
  1. CD70 firmware update problem
    By C-Owner in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2011, 21:15
  2. CD70 update problem
    By delica1988 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2009, 20:18
  3. CD70 Update CD
    By MattDC in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2009, 21:52
  4. CD70 update cd
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 10:59
  5. cd70 update?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 21:30
