Thread: Another I.C.E problem
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Another I.C.E problem
    I have recently fitted my Kenwood Dpx 501 (double din cd player with usb) to my 2003 2.2Dti. At first i thought there was a problem with the head unit (which i have had fitted to two other cars) because the stereo was turning on and off with just the ignition on. When the car was started the stereo came on and worked fine. Now i have noticed that when i turn the engine on if i turn the steering just after it has started the radio goes of and comes back on.
    The aux belt of the car sometimes gives a sqeak when it is first started so i think either it needs a new belt, the alternator is gone or there is a problem with the battery.
    Has anyone suffered ant similar problems with this. Thanks in advance
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bump
    Oct 2006
    Wellingborough
    Quite common for lights to dim when steering due to the current draw of the power steering system. I would connect up a meter and check your voltages, could well be alternator on it's way out.
    Regular Member Robward27's Avatar
    Witham
    Might need to run in larger perminant live from cigarette lighter depending on what the headunit uses.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers guys i'll try the alternator voltage first failing that i guess ill have to wire for the cig lighter
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
