Thread: VXR insert/diffuser advice pls
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Default VXR insert/diffuser advice pls
    Right guys, on Tues im gona get the VXR insert installed and put the twin pipes on the car. Seen a few threads where some needed to cut bits off the bumper, I'd thought it was a straight swap for the SRi insert? What exactly do I need to do? Anyone give me mini instructoins for the facelift or some pics of instalation? do i need to purchase new clips etc beforehand? cheers in advance people
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    all you will have to cut off is the moulded bracket's that will impeed the exhaust's, they are about 1'' wide and they get in the way..and you will also need a few new push rivit's to fix the end's to the bumper where they come around the edge, other than that it is a straight forward but tight fitting job...
    Midlands Mod Shop - NFFC.
    Nov 2007
    Aberdeenshire
    is that on the bumper or insert m8?
    Trim : Get a
    the bracket's are on the bumper mate....about 1'' wide and 3'' long, you will see what i mean when you remove the sri insert...
    Nov 2007
    Aberdeenshire
    perfect, cheers m8 Should have pics up middle of the week!!
    Regular Member VectraMat's Avatar
    Hull
    Quote Originally Posted by ditchp View Post
    Yep had this problem when i fitted mine, easliy fixed though as Rich mentioned.
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    went to collect my VXR insert today and they told me that VX are havin a problem with the stock levels... gutted... my bumper is due in the painters on tuesday
    Nov 2007
    Aberdeenshire
    Its a great mod, and pretty cheap, only thing is its got me wanting to do more!!!
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Just done mine!! Just cut the brackets off, the insert wont fit otherwise!!
    shropshire
    where can u get these push rivets from ?
  1. Imscher exhaust insert and XP1 rear diffuser
    By John LE in forum Styling
    Last Post: 5th March 2013, 23:05
  2. 888 rear insert/diffuser....
    By danBoy in forum Parts for sale
    Last Post: 21st July 2009, 20:43
  3. VXR rear diffuser/insert
    By hideyspidey in forum Styling
    Last Post: 19th July 2009, 16:22
  4. VXR Rear Diffuser/insert
    By vauxhall4life in forum Styling
    Last Post: 29th February 2008, 11:38
