Thread: Front "V" Painting
    Regular Member Simo87's Avatar
    Jan 2008
    Middle Wallop
    Default Front "V" Painting
    Just a quickj Question really and sorry if it is answered anywhere, but ive been looking since 3pm lol,
    when painting the front "V" does it need to be primed first?
    or do you just spray over it??
    Many thanks simmo
    Regular Member swainey's Avatar
    Newtown Powys
    yes prime it first
    Quote Originally Posted by swainey View Post
    yes prime it first
    thin coat's always work best hth ...............
    Regular Member corsa_si's Avatar
    Apr 2009
    Sheffield
    You need to sand it back to get rid of uneven surfaces, then put plastic primer on it, then primer, then paint, then lacquer.
    Regular Member cameraman's Avatar
    Leicester
    Needs to be rubbed down too if it's the chrome effect one, otherwise it'll come off with the next jetwash
    Apr 2009
    Sheffield
    Quote Originally Posted by cameraman View Post
    Do this and don't forget a liberal amount of plastic primer otherwise it'll flake off. If you do it right you'll never have to paint it again.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    good prep is always the key in painting anything...
    Midlands Mod Shop - NFFC.
    Jan 2008
    Middle Wallop
    thanks for the hasty replys, will give this a bash 2moro, guessing a bit of wet n dry folowed by some plastic primer wouldnt go far amiss?
    Regular Member jos163's Avatar
    North Wales
    Definately prime it mate as the guys say. It should look good then with painting. Should last years.
    Trim : Get a
    1200 / 1500 grit wet/dry will be good mate, have to make sure you get a good key for the primer to stick correctly....then same again on the primer to flat it and provide a key for the actual colour
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. HID conversion "front bumper removal"
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2012, 17:45
  3. Front Drop Links changed on the "B" and.....
    By Vaux-Man-G in forum General Chat
    Last Post: 6th April 2010, 09:31
  4. painting the "V"
    By wangerdanger in forum Styling
    Last Post: 15th March 2009, 17:33
  5. "Grating / Rubbing" noise from front end
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2007, 17:05
