Thread: ice problems !!!!!!
    harlow,essex
    Default ice problems !!!!!!
    i am after some help,
    i am FINALLY getting my subs and amps fitted to my 03 vectra (been almost 3 years now since i bought the car).
    Been told by a couple of people that the main ecu will go bang if i dont fit a surge protector because of the sudden drain/surge that turning the amp on will cause !!!
    Anybody got any ideas on this ? Or have you fitted amps/subs without any problems
    Many thanks gang
    Rob
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    afaik mate, some folk fit a powercap to help keep the voltage up but not heard of a surge protector to stop the ECU going bang........
    Midlands Mod Shop - NFFC.
    Regular Member Lump's Avatar
    coventry
    think you been told a porky mate
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Not heard that before mate (although my Colt engine used to surge if i was cruising with the tunes going loud)
    Got a couple of Amps subs etc in the veccy for 2.5 years now with no problems although i did fit an external battery in the boot with a split charge so this does take most of the load but not all.
    (Can still see glovebox / interior light dim with a thump of bass - as the rear battery takes from the front)
    harlow,essex
    thanks guys will have a go and see if it works ok and will get back to you !!
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Nae m8 got two amps in mine one to power the sub and one for the 6x9's had no probs
    Regular Member Robward27's Avatar
    Witham
    I have 3 on mine with no caps as of yet 1x1000w, 2x900w had no problems. Would recommend a power car im getting one for each amp!
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
