Thread: caravanning problem
    Oct 2006
    spalding
    Default caravanning problem
    hi all, my caravan seems to bring out the worst in my car-- the dreaded car and spanner reappeared! this has only happened recently whilst towing the van 300 miles home from Devon!! Not the ideal thing whilst alongside a lorry on the M5. We had the problem before about a year ago and vauxhall replaced the mass air intake filter and then the pressure sensor valve, which has been ok up until now. The problem happened once on the way to Devon whilst towing, car was ok all week including some challenging 1:4 hills then problem reappeared several times on the way back whilst towing again. Does anyone have any ideas what the problem can be - don't really want to sell the van.
    Thanks for any help.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Manual or auto box?
    EVERYWHERE
    Probably boost pressure sensor is gummed up again.Try squirting carb cleaner into small hole on sensor when it's removed.But before that,get the codes read.
    Oct 2006
    spalding
    manual gearbox. sorry, i should have said. i was hoping to avoid the code reader, it`s even led me to go looking at mond**s today, it`s getting serious!
    Castle Donington
    I can tell you the problem straight away....... your pulling a caravan nuff said :P
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    It's the caravan car's dont like them.
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Loose the caravan other car users dont like them....!
    You didnt say what engine / model it is?
    Apart from that it's worth checking all your pipes for splits or cracks and possible giving the EGR valve and boost sensor a good clean out.
    There are how 2's in the how 2 section and if you clean out the EGR valve and drill the solenoid side know out clean and greese with copper slip it cant hurt at all.
    Other than that you should'nt be towing at over 60 MPH so stay at home on your drive with the van or behind the lorries so you dont hold up the rest of us!
    Oh and if you could travel between 2359hrs and 0500hrs only on Tue Wed or Thurs only that would help too!
    Regular Member Drew's Avatar
    Sedgefield
    Could it be the caravan electrics causing the problem? Who installed the towbar and electrics on the car? If it only goes wrong when the caravan is hitched up it would be worth having them checked. i tow from Co Durham to Cornwall every year and have had no probs. I don't hold anyone up either!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    My 2.2dti pulls like a train and i dnt hang about with the van on.
    Regular Member Gerdo3's Avatar
    Blantyre
    *******, vectras pull like a train, my cdti150 will cruise at 90 all the way to devon & flys up telegraph hill, it cant be your van, unless you are over 85% of the car weight then u have problems, more than likely egr valve needs cleaned
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. A not so cheap caravanning weekend
    By Dave1.8 in forum General Chat
    Last Post: 14th September 2010, 14:36
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
