Thread: Questions about brake upgrade
    Regular Member baard's Avatar
    Norway
    Post Questions about brake upgrade
    I have read that some of the best brake upgrades for 1.9 CDTI, can be made by changing the 278mm fronts for either a set of 302mm from a 2.0T or the 314mm from a GSi/3.0 CDTi.
    I have a few questions about this:
    Is the “314” brake upgrade similar to the brakes used in VXR/OPC brakes ? Can I use my 16” winter wheels in occasion of any of these brake upgrades, or do I have to buy me a set of new wheels and winter tires ?
    I take for granted that if I do a brakeupgrade, I have to change both discs and callipers, and of course pads ? Does anybody have a view of which parts that needs to be changed, and the no for those parts ?
    Is it just "plug and play" ?
    Buy the way, spring has finally arrived in Norway
    Best regards Baard
    Do a search for 314 brakes as there is plenty to read. I am not sure they will fit your 16" winter wheels hang on for more advice, pleased to say spring is here also .....
    Regular Member adfrodsham's Avatar
    lincoln
    i think 17's is the smallest for 314's, ive got them and the weights only just clear
    Ashington, Northumberland
    Yep, as stated already, the 16's are too small to accommodate the 314's. Plenty of people have 17's on with 314's though.
    Mileage : 000
    I have 17" as standard on mine with 314 m/m discs, as Standard on 3.2 v6 04 reg onwards too.
    Belfast
    You NEED 17" rims for the 314mm brakes. The 302mm should fit with 16".
    I've a 302mm setup waiting to go on my motor sometime, they'll go on when the standard mountain bike brakes wear out.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    as above 17" is the min m8.
    Norway
    Thanks fellows !.
    And if I have understood it correctly from reading on this forum, 302 and 314 brakes are both plug and play ?
    One more question: Do I have to remove the original brake shield, or does it contain room for new bigger discs ?
    Quote Originally Posted by baard View Post
    Thanks fellows !.
    Throw it away as I understand ............................
    Norway
    Sorry to trouble you once again, but I have more "brake-questions".
    I have been searching for places to get hold of "314 brakes". If I’m not wrong, I remember reading some place in this forum that the 314 brakes are similar to the front brakes used on Saab 9-3 SS Aero. (mod 02-)
    When I search for brakes on Saab 9-3 Aero, it seems as if they use ATE brake callipers in front. As I recall, the brake callipers used on Vectra are all marked GM ? Or, are these
    similar to ATE callipers on Saab 9-3 Aero ?
  1. Gsi brake discs/pads questions.
    By big rich in forum Engine & Drivetrain
    Last Post: 9th October 2011, 18:14
  2. Brake Questions
    By Colin_GSi in forum Handling & Braking
    Last Post: 21st November 2010, 12:20
  3. Questions about CD30 MP3 upgrade
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2010, 09:53
  4. brake questions
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:14
  5. Rear Brake Questions
    By retroandy in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2009, 22:12
