Results 1 to 10 of 13
Thread: Signum spanner through car light
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    Default Signum spanner through car light
    This is my first post and im looking for some advice,i bought my signum 19cdti (150)34000 miles 4 wks ago and originally when u turnd the ignition on the light showing a picture of a car with a spanner through it would come on and go out after about 2 seconds,but over the last few days it stays on untill the car is started and then goes straight out and stays out is this normal or should it not be coming on atall ? still under warranty untill october but just want to no what it could be before i go rushing down incase its nothing to worry about.any info would be a great help cheers steve.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    This is a fairly common trait with all vauxhall sigg,s and vecs . As a guess i would say a glow plug fault , but if you are concerned have it tech 2 ed, I have had the same thing happen to my siggy every day for the last two years and it has not been detrimental to performance or starting at all
    and still loving it
    Regular Member the fisherman's Avatar
    manchester
    i have it onmy vectra at moment.its going in for service tuedsay so ill no what it is hen
    Quote Originally Posted by bobssignum View Post
    had it once never since ..........................
    Apr 2009
    CO DURHAM
    thanks for the advice its much appreciated,cheers steve
    Full Member Big Sig's Avatar
    i'd book it in to get the codes read. It means its had a fault so get it fixed
    Regular Member adfrodsham's Avatar
    lincoln
    my car does it at start up,always has and no fault codes on mine, was told be vauxhall its normal ?????
    its not normal on the preface lift. Check the manual but fairly sure it shouldn't come on unless it sees a fault.
    Glasgow
    If it goes off once the car is started there was a fault PREVIOUSLY and your owners manual tells you this is nothing to worry about. If it STAYS ON then book it in. HTH
    Apr 2009
    CO DURHAM
    thanks for all the info,its a 56 plate i think i will book it in to get checked to be on the safeside
  1. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  2. spanner light on my Signum 2.0DTI..help pls
    By cermi in forum Engine & Drivetrain
    Last Post: 5th December 2009, 08:38
  3. 3.0 DTi Signum EM light with spanner?
    By Agoogy in forum Engine & Drivetrain
    Last Post: 24th June 2009, 16:46
  4. signum spanner light
    By keith_johnson1967 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 17:01
  5. Signum 2.0DTI spanner light
    By signum_boy in forum Engine & Drivetrain
    Last Post: 17th May 2007, 22:00
