Thread: what are the service intervals on my cdti 150?
    St Neots
    Default what are the service intervals on my cdti 150?
    thanks its a 2004 if that makes a difference
    and what should be changed at 72k?
    lanarkshire
    have mine serviced every20k change oil every 10k done 115000mls no probs except springs n front hub 2 rear shocks usual disks n pads
    wiper linkage 2 and the injector loom sorted with cable ties @ 70000
    very reliable otherwise
    St Neots
    my rear discs and pads a fooked lol gunna get them changed next week hopefully
    brakes are binding to so will give everything a clean at the same time
    Belfast
    80k is timing belt, so it'd be a very good plan to get that done.
    Is the car on ECO Flex servicing (with the key out of the ignition, press the odometer and see what the range to next service is)?
    What is the service history up to this point?
    The car should be every 20K miles / 2 years, so it seems a little unusual that it is having a service during 2009, unless the car usage has changed or you are a high mileage driver
    I wasn't aware a cambelt was due at 80K miles, for the 1.9 CDTI it should be 10 years / 100K miles
    St Neots
    thanks for that mate
    i'm on 71k at the mo and it had an oil change when i bought her 3 months ago when the mileage was 65k, so i'll wait till 80k for a service
    thanks
    Belfast
    But recommended 80k. You're really dicing with death running it to a full 100k. Good chance the tensioners will die long before that anyway.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    as zs says get the belt/belt kit changed as you will be in deep trouble if they go
    Leicester
    If a cam belt goes on a 1.9 150, it is not the end of the world. It doesn't take out the whole engine. Normally just brakes the rockers.
    My dealer just did a 2005 1.9 150 that had a failed cam belt, 121,000 miles on the original cam belt, final bill was around £600. Which is not bad considering it was a Vauxhall dealer.
    But regarding service intervals, in 2004 the 1.9 150 had 2 year 30,000 miles service intervals.
  1. 3.0 CDTi V6 Service intervals?
    By pwjolly in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2007, 07:55
  2. 1.9 cdti service intervals
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 18:41
  3. service intervals
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 17:18
  4. CDTI 150bhp service intervals??
    By garner in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2007, 17:26
  5. vxl change service intervals on cdti
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2005, 12:01
service interval for high mileage 3.0cdti signum
service intervals vauxhall vectra 1.9cdti
