Results 1 to 3 of 3
Thread: will they or wont they????
    Cambridgeshire
    Default will they or wont they????
    i konw two people on here have 19" RS6 rims and they look nothing short of amazing but can a smaller size be fitted without all the hassle?? instead of modifying the actual rim to make them fit!! i want the rims when i finally get a vec but seems alot of effort and money!?!?!?!
    also while on the subject will the 5-series M-Sport rims fit (see below if unsure what im on about)
    http://www.essential-b-mparts.co.uk/ad1.jpg
    cheers people
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    merc / vw-audi rim's have to be machined as the centre hole is too small and the pcd is reached by using wobbly bolt's....bmw rim's can be fitted if you but the spacer's with lug's on iirc they are about 20mm in thickness so the wheel's will stick out further than the arches...
    hth
    Midlands Mod Shop - NFFC.
    Cambridgeshire
    cheers for the info matey so basically both sets are a pain in the arse to fit, i havent found many other rims i like for the vec i love snowflakes but far too poor and lazy to bother with ebay bidding wars for a set, black rims arent my sorta thing, white i could cope with if i found a good style that i like at this rate i will be leaving the trims on for quite a while after geting the car!! Rims can make or break a car so choose carefully!!!
  1. Will They Or Wont They ?
    By Tam80 in forum The 'Off Topic' room
    Last Post: 16th May 2011, 16:23
  2. You wont believe this!!!
    By mushy2007 in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2008, 11:55
  3. why wont it fit :(......
    By b4r0n in forum Styling
    Last Post: 21st May 2008, 21:54
  4. Wont rev over 4,500 - please help !!
    By duracell in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 15:40
