Results 1 to 10 of 20
Thread: Ignition Switch replacement
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default Ignition Switch replacement
    I have had a problem starting the car today and Green flag have come out and said it is a faulty ignition switch. does anyone know how easy it is to replace and what sort of cost is a new one. he says it is a common fault so someone must know what to do. the car is a 2.0DTi
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Remove steering column shrouds, insert key into ignition and turn to position 1, insert a thin rod into the hole in the lock housing, press the rod to release the detent spring, pull out the lock cylinder using the key. Replace lock with key in position 1, remove rod from housing.
    Regular Member Ben999's Avatar
    Milton keynes
    There is a vauxhall one on ebay for about £15 with postage. Although it doesnt fit a car with tilt stearing. But gives you a guide for the price.
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    I have just had a call from Vauxhall saying that the part will be £134 and it need programing in is this right or are they trying a fast one on me
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it the actual switch or the immobiliser pickup module that is defective?
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    just the switch if you trun the key a few times the car starts
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    vauxhall have now come back and just told me that the switch cannot be bought on its own and is fixed into a module that controls the stearing wheel controls and wiper/indicators and now want over £500 just for the part
    Mileage : 000
    I would try or at least ring another VX dealer. I replaced the ignition barrel on my wifes Vectra B. The barrel cost £45. I would presume they are both simalar.
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    they have told me that i cant get the switch on it own
    Regular Member garvey's Avatar
    Co Durham
    could it be the ABS plug
  1. Replies: 2
    Last Post: 4th February 2011, 21:33
  2. Ignition barrel replacement video ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2010, 15:01
  3. Ignition replacement advice please
    By bighammerfan in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2010, 11:07
  4. Ignition Switch Wire
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2008, 17:05
  5. Ignition switch wiring please!
    By blue estate in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2008, 00:05
ignition barrel collapsed vectra c
replacing ignition barrel vectra c
vectra b ignition switch replacement
vectra c ignition lock
