Thread: Dave's mini diesel test......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Dave's mini diesel test......
    Car - 2.2dti
    mileage - 109k
    year 2002
    test:
    use a variety of fuels and note their performace, making sure that I run a particular fuel more than once.
    standard BP diesel - 43.40mpg
    standard BP diesel with millers - 43.57mpg
    shell v power diesel - 44.60mpg
    shell v power diesel - 43.97mpg
    not exactly conclusive, but I will continue. the only problem is the fact that this next tank will involve a lot of motorway, so it should climb.
    cheers.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    I find millers gives me about 2mpg more on standard shell diesel
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Not only unconclusive, the differences are so close as to be within measuring error. Less than 2% is insignificant IMO and cannot be considered as a real difference. I would ignore any difference of less than 5% as a minimum.
    Suffolk
    Default update - 02/05/09
    bp ultimate - 44.13mpg
    bp ultimate (on a run) - 50.50mpg
    bp ultimate - 45.00mpg
    look like bp ultimate is winning but it cost 6p more a litre over std.
    0.06p x 47 litres - £2.82 a tank more.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Doing the calcs.....
    I have compared the 1st standard BP (worst) against the (best) ultimate economy (ignored the 'on a run')
    and assumed 92p/l for normal and 98p/l for ultimate.
    The difference, based on 30000 miles a year, is that the normal fuel would cost £80 less for the year. So even though there is a marginal fuel economy gain (and I will assume that this is right, and not normal tank to tank and car usage variation, for the purposes of this calculation), then as it is more expensive per litre (6p), the ultimate is more expensive than normal unleaded.
    Therefore,
    Normal unleaded is cheaper to run than ultimate....
  1. Various Diesel liquid and adons test
    By kingarthas in forum General Motoring Chat
    Last Post: 2nd March 2012, 13:55
  2. Diesel Leak-Off Test vs Diagnostic Software
    By snapsnap in forum Engine & Drivetrain
    Last Post: 10th October 2010, 20:04
  3. Dave's bebo!
    By david173 in forum General Chat
    Last Post: 29th September 2006, 06:46
  4. Dave's Trax 2006
    By Dave Vec B in forum 2006
    Last Post: 10th September 2006, 22:49
  5. Dave's southport
    Last Post: 6th August 2006, 23:57
