Results 1 to 10 of 13
Thread: Engine fault ???????????????????
    Apr 2009
    wales
    Default Engine fault ???????????????????
    Hi All, I have an intermitting engine fault and have no idea what to do to fix it. I have a vectra 1.6 16v on a R reg, its a lovely car but recently have stated to play up. When I'm driving the engine management light will come on and at the next junction the car will not idle and just cuts out, it will then start straight away and the engine management light is off and the car will drive fine for about 2 days and then do it again. I've tried to get it checked in the garage but I was told the light would have to be on for them to find the fault. Have anyone had this problem or know what it is please.
    Cheers Tony
    Mileage : 000
    Sounds like the air control valve on the side of the throttle body. Have you tried spraying Carb cleaner into the Two small holes on the left side of the inside of the throttle body. It is best if you can remove the Air control valve and clean it. But a squirt of carb cleaner in the holes mentioned should improve it. You might need to get a new Air control valve in the end though.
    If you do " the paper clip" trick it should tell you the fault code, and in turn the reason for the ECU light coming on.
    Apr 2009
    wales
    Cheers Ed I'll check that out. Not sure what the paper clip trick is though.
    Regular Member david.aka.judas's Avatar
    Suffolk
    hi mate,
    hope you're well?
    I hope the car is better now, if I was you I would join a vectra b website and the chaps on there will tell you.
    but you are more than welcome to ask any questions here...
    all the best and have a really good easter.
    cheers
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by Judas View Post
    wee bit harsh dont ya think lol
    Suffolk
    Quote Originally Posted by thegoldenbullet View Post
    no i dont actually, I didn't mean it to come across that way at all......
    i shall revise.
    Mar 2007
    Grimsby, Lincs.
    i shall revise.
    lol loving the revised version lol
    11 Post(s)
    Quote Originally Posted by tony24 View Post
    http://www.topbuzz.co.uk/info/fault_...ault_codes.htm
    ps, won't work on facelift Vec-B's or any Vec-C's
    Suffolk
    sorry ed.....lol
    Mileage : 000
    sorry ed.....lol
    Ok.
  1. engine fault please help
    By neill in forum Engine & Drivetrain
    Last Post: 7th August 2011, 06:28
  2. 2.0 dti engine fault
    By huddsy in forum Engine & Drivetrain
    Last Post: 8th April 2011, 21:36
  3. Engine Fault?? Need Help Please !!!
    By bigpaw35 in forum Engine & Drivetrain
    Last Post: 6th August 2009, 21:47
  4. Engine Fault Code
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 18:34
  5. Engine Fault
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 13th December 2005, 22:08
