Thread: traction control ... again
    Regular Member fireblade's Avatar
    Feb 2006
    at home
    Default traction control ... again
    I know this has been covered a few times in december last year but has anyone got the tech2 to make the switch work?
    All the ones i know that worked plug and play were the 2004 year model or older(not full can-bus) has any one got the switch to work on 2005 on cars (full can-bus, cd30 type radio)
    If anyone has got it to work on the tech 2 where in the settings is it?
    mine is in the dealers to be looked at(unrelated fault , swirl acctuator faulty?) have asked local dealer before who did not know where it was in the settings to enable switch to work
    Leicester
    I have found thatn if you have fitted a switch and the TC does not become switchable, then you can't activate it by Tech 2.
    It has something to do with the ABS/TC modules, apparently it isa big job to do, if at all.
    Here, there and every where!
    Mine is the 2005 full canbus and the switch does not work. When i asked the "technician" in Vx dealers he did not think it could be done. But then i don't think he knew what day it was either
    Regular Member The Doc's Avatar
    'Norf Yorks.
    It is still one of the things I want to fiddle with so i'll keep you posted.
    Though as Matt says I see it being an issue.....
    Mine is 2005 full canbus as well I think.
    PMSL @ Caterman's comments
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
