Results 1 to 2 of 2
Thread: removing steering column cover
    Kingston Upon Hull
    Default removing steering column cover
    Hi can someone tell me how to remove the column cover
    the reason is if i turn the wheel full right the air bag light comes on so i want to have a look to see if i can find a cut wire or something
    Jacko52
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    IIRC Two screws either side of wheel just turn a qrt each side and remove,then remove dash trim on both sides as top cowling is secured on by two clips either side,then remove top cowling
    Pop off ignition cover and undo steering height adjuster by undoing 2 screws holding this on and underneath that is another screw then finally two screws on top either side of wheel from where you've removed top cowling (it was underneath the cowling) HTH
  1. Steering column help please
    By TopRod in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2012, 11:08
  2. steering column shroud
    By chaddopete in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 17:13
  3. steering column problem
    By veiluoks in forum Engine & Drivetrain
    Last Post: 4th October 2009, 16:19
  4. steering column
    By robjones in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 18:32
how to remove steering column cover vauxhall vectra
https:www.vectra-c.comforumshowthread.php77681-removing-steering-column-cover
vectra steering column contacts
vectra c steering wheel shroud removing
step by step vectra c steering wheel shroud
removing vauxhall vectra steering cowling
removing vectra c ignition colum
vauxhall insignia steering wheel cowl removal
how to removevectrc steering wheel cowling
