Results 1 to 10 of 13
Thread: High Oil consuption
    Castle Donington
    Default High Oil consuption
    Hi all, I have a 2.2 sri with about 85k on the clock. Engine had a rebuild about 9 months ago. Its completely unmodified other than the airbox mod.
    Ever since its rebuild its develolped a rather unhealthy addiction to engine oil. It doesnt get thrashed and covers between 400 to 700 miles a week.
    It usually pops up the low oil light once a week so i check it and top it up. Now to me this seems a bit excessive.
    The car doesnt smoke, its not leaking from anyware i can see and the breathers arnt blocked. Im reasonably handy with finding and fixing faults but this one is baffling me.
    ideas would be appretiated
    Mileage : 000
    Have you done a compresion test to see if all the cylenders give the same reading. Whilst you say the engine has had a rebuild and does not smoke. Get someone to watch the exhaust when you start up from having left the car standing over night, just to check that oil is not running down the valves via worn valve stem seals. Also have you had a friend follow you and look for a "puff" of smoke when you change gear. How many mile ago did you say the rebuld was. Maybe the engine is not fully bedded in. I did hear somewhere that if you put fully synthetic oil in it will take longer to bed in. I don,t know how true that is though.
    Castle Donington
    Hi Ed, Comp test is ok. Only gas from the exhaust when cold is the normal steamy stuff you get from every car that clears up after a few mins. And no one has mentioned any puffs of smoke on gear change, will have another look tonight with a large helping of man foot. I think its done about 10-12k since the rebuild and yep its had fully synthetic oil.
    Mileage : 000
    When is it due for an MOT might be worth seeing if there are a lot of Hydrocarbons in the reading. But they would need to be Very high I recon. How much oil did you say you had to put in every 500/700 miles?.
    Castle Donington
    Not due untill june/ july i think. About 1 litre it varys
    Regular Member xrken's Avatar
    northampton
    stick some slick 50 in with your next oil change
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Oil scraper rings! Its a common fault on the 2.2. Mine lost 1L over 1k and VX replaced them under warranty. HTH
    Castle Donington
    Cheers rushy, shame I have no warranty no more. Is there anything actually good about the 2.2
    Vehicle : SRi
    Mileage : 137000
    If the chains fine then its a great lump mate. I take it you have a hatch, if so you dont have the fueling problem the direct has. VX say that 1L per 1k is within normal parameters by the way.
    Castle Donington
    yep tis a hatch. they are a bit under powered though.
  1. vibration when accelerating and poor fuel consuption
    By markydj72 in forum Engine & Drivetrain
    Last Post: 1st November 2012, 22:35
  2. would you buy high miles?
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 20:02
  3. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  4. high oil consumtion
    By bombai in forum Engine & Drivetrain
    Last Post: 14th February 2011, 12:45
  5. High 5
    By Leviathan in forum The 'Off Topic' room
    Last Post: 17th February 2008, 02:06
