Results 1 to 10 of 22
Thread: Rain Sensitive Window Wipers
    north west
    Default Rain Sensitive Window Wipers
    I am finally getting to grips with the sigmas controls now after switching on the cruise control instead of changing the cd track lol anyway rainsensitive wipers when i was driving today IN THE RAIN they had to be turned on manually is there a switch on the stork it should be set at,this probably could be a dumb question.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    they shouldn't even be called rain sensitive wiper - more like semi as like you say they need to be switched on and off manually. The only thing the sensor does is control the speed.
    Gazza4
    north west
    Default ...
    Now that makes a bit more sense thanks gazza
    Full Member gibbon7000's Avatar
    lincs
    I hate them, there pants imo. I hate it when they go full speed, in 15 yrs of driving i've never used my wipers on full speed. My Laguna was just the same, had to switch them on
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I like them. Remember they only work in rain-sensing mode in what would otherwise be the intermittent setting, and can be overridden for higher speeds by moving the stalk upwards. It starts raining, and I move the stalk to the first setting, and let them do their job adjusting the sensitivity if required.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    they are switched off by default and for a very good reason,you would not want your wipers going when the blades are stuck to the screen,one burnt out motor later,it is the best way so you have to activate them.
    as to it being mentioned about the sensor only adjusting the speed,how do you work that out? the sensor tells the control unit how wet the screen is and tells the control unit when to activate the wipers,only when the screen is very wet does the speed vary,it has been mentioed tht the rain sensor is cr*p,you want to try the system fitted to the citroen xsara,that had no adjustment at all,it was easier not to use it at all,the vectra system is brilliant,if your wipers go too fast you have the sensitivity set too high,try turning the scroll wheel to the left,that is where mine is and i have no problems with the wipers going flat out
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by solorider View Post
    Also try going thru a drive-in car wash if you've forgotten to switch your engine off LOL
    Rain-sensitive wipers are only activated as they are needed and at the speed they are needed, thereby optimising wiper use and reducing wiper wear.
    Regular Member MCD's Avatar
    NE Manchester
    35 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Got them on my wifes Astra... right pain in the arse! When its ever so finely spitting, they wont come on in sensor mode, so have to turn them onto normal speed as there is no other way of getting variable intermittent wipe... so annoying!
    Mike
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You won't find many (if any) that have fully automatic wipers, Peugeots, Jags, Ford etc... they all have to be switched on first.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    my farther inlaw has a nissan theres its fully automatic.
  1. Rain sensitive wipers
    By jan65uk in forum Bodywork & Interior
    Last Post: 23rd January 2010, 22:17
  2. Rain sensitive wipers rant..
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 03:51
  3. Rain sensitive wipers
    By Wilco in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2008, 09:58
  4. rain sensitive wipers
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2007, 19:58
  5. Rain sensitive wipers
    By NRG in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2006, 10:01
