Thread: Factory Bluetooth microphone Wiring
    SUFFOLK
    Default Factory Bluetooth microphone Wiring
    A quick question for those who have either retro-fitted the factory Bluetooth (as I have) or used the vauxhall mic and roof wiring as part of an after market kit.
    Has anybody had issues with low microphone volume? It does work if you shout or are very close to the mic but is currently not really usable on the move.
    I'm guessing it probably requires better quality cabling and solder the wiring in one big run rather than going through a series of connectors.
    However, before I pull the wiring loom apart again, any thoughts on best way to fix this appreciated.
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    it doesnt matter wot cabling is used as long as its proper copper core wiring,
    as ive used the exact same when i fitted it to my signum and it was clear
    as a whistle,have you tried to adjust the volume on the head unit etc
    but theres no specific volume for the bluetooth though but worth a try
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Chester
    No need to shout. Just the same volume as if you are talking to someone in the passenger seat.
    SUFFOLK
    In that case think I've got a weak joint in one of the crimps in the wiring loom.
    At normal speaking volume it fails to pick up much at all.
    At least it sounds like from Andy's description the basic cabling loom itself is probably ok and just need a joint repair somewhere.
  1. Microphone for factory bluetooth
    By pipamish in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2012, 00:37
  2. microphone for bluetooth kit
    By gizmo10119 in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2011, 12:33
  3. Bluetooth Microphone Kaput
    By Aidi in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2010, 21:49
  4. Vauxhall Bluetooth Microphone
    By plasma in forum Parts for sale
    Last Post: 26th March 2010, 19:13
  5. CD70 Bluetooth (Factory Fit) - Microphone problem ?
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 00:52
