Results 1 to 10 of 14
Thread: clunk from steering
    newcastle upon tyne
    Default clunk from steering
    When stationary and turn my steering wheel from side to side im getting a clunk in the middle. I got our lass to wiggle the steering wheel while i had a look and it seems to be coming from the steering colum somewhere. There doesnt seem to be any play in the universal steering knuckle. Any Ideas lads, any suggestions welcome.
    WGAF#5
    could be a "flat spot" on the steering rack ?
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Not sure on that one, might be your steering rack going, how old is your car?
    Regular Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    definately a clonk? probably the rack.
    If its more of a creek i'd say check out top mounts first.
    Glasgow
    Before you splash out on a whole new rack check the track rod inners, a known fault/weak spot and very prone to wear. When i did mine the dealer i went to had more than 20 in stock, nuff said.
    Jim.
    newcastle upon tyne
    Cars a 2005 with 125000 hard miles, defo a slight clunk like somethings a bit loose. Also how do i check inner track rods and are there any bushes down the rack because a ford sierra i once had did and were prone to wear.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by shrekster View Post
    Jim.
    as above, check them first before spending loads
    Glasgow
    Jack the front wheel up, firmly grasp the wheel in the 9 and 3 o'clock position and try to rock the wheel left and right. There should be no play at all, if there is check the track rod ends, both outer and inner. If your not sure any decent garage should be able to check for you for free.
    Jim.
    East Midlands
    Mine used to have a slight squeek when turning steering wheel whilst parking etc,what i did was grease the top mounts when i changed the front springs and it seems to have cured it,could be worth doing on yours and it is a known fault on the vecs apparantley.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    it would ether be the tie rod, track rod ends or the bottom balljoint
  1. Steering play/clunk
    By byebyeitsagsi in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2013, 19:07
  2. vectra steering clunk
    By stooby in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2011, 12:01
  3. Big Clunk
    By Ben_ in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2011, 15:03
  4. Clunk..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 21:53
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
vectra c clunking when turning steering wheel
