Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: 1.9CDTI and 'Turbo Lag' – Your Opinions
    Wales
    Default 1.9CDTI and 'Turbo Lag' – Your Opinions
    Having driven a few new-ish diesels recently, they have made me quite aware of the turbo lag on my 120bhp
    What are your opinions on it and do you find it ‘bad’ (120 or 150)
    The golf I have just handed back would quite happily pull away in second and trundle along with 1300rpm showing and no 'juddering'. By compariosn my CDTi hates doing this and needs muchos clutch slip for a 2nd-gear pull away!
    Its odd because looking at the torque graphs on the BSR website, they both have roughly the same amount of torque at around idle/sub 1500rpm. (I appreciate mine is probably a good few 100’kg heavier though)
    Cambridgeshire
    I find it a bit of a struggle when the engine isn't up to temp. Once it is then there is hardly any lag at all
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    A correctly running CDTi will happily pull from just under 1500rpm - but most have "issues" and don't correctly pull till 2K.
    Running right, I don't have any issues with the so called "turbo lag" of the CDTi's.
    Regular Member silverhairedracer's Avatar
    ESSEX
    Never had a problem.
    Full Member Big Sig's Avatar
    Its horrible lag, hence the reason I bought the V6. Although some don't mind or notice it so its down to driving style????
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Are we talking about turbo lag, or boost pressure creation performance (ie performance mapping)?
    The 2 are not the same.
    Flooring it at 1300 rpm and not a lot happening until the revs get up to 1800 rpm is NOT lag.
    Wales
    Can you expand mate? If this helps..
    I liked the low-down grunt from tickover (1000rpm) on the 2.0ltr golf
    I dont like the seeminly gut/grunt-less nature of my 1.9CDTI low down.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Quote Originally Posted by Ste View Post
    Whatever it's called, this is what would put me off. Only driven one once and I wouldn't be able to put up with it on a daily basis.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Never noticed this lag people talk about from the 1.9 on mine! whether that's because it was remapped before it had done 500miles or not I don't know..
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    turbo lag is a nightmare on mine
  1. 1.9cdti(150) turbo
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 19:44
  2. 1.9cdti turbo
    By olblue in forum Engine & Drivetrain
    Last Post: 15th March 2011, 00:40
  3. 1.9cdti Turbo Hose
    By bgm46 in forum Engine & Drivetrain
    Last Post: 17th June 2009, 22:33
  4. Twin turbo on my 1.9CDTI...
    By nutron in forum Diesel Engine related
    Last Post: 18th August 2008, 20:09
  5. where does the turbo live (1.9CDTi)
    By pigdog in forum Engine & Drivetrain
    Last Post: 8th August 2007, 16:16
vectra c 1.9 cdti turbo lag
vauxhall insignia 6 gear lag
vauxhall zafira turbo delay
150hp cdti turbo lag
insignia cdti turbo lag
opel zafira what causes turbo lag
vauxhall zafira 1.9 cdti boost lag
1.9 cdti lag
astra h turbo lag
z19dt turbo lag
1.9 cdti sooting
1.9 cdti turbo lag
vauxhall vectra turbo lag
my vectra is lagging
turbo lag on vectra o4
cdti 110kw turbo lag
vectra cdti z19dt turbo
1.9cdti turbo lag
astra 1.9 cdti turbo lag
vauxhall insignia 2014 turbo lag
vectra cdti no turbo lag
vectra c 1.9 cdti sport button
vectra c turbo lag
should i use redex on my VAUXHALL 1.9cdti engine
