Results 1 to 10 of 16
Thread: Mondeo 1995
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Default Mondeo 1995
    Hi People
    Wondering if you can help me with a problem a friend is having problems with his car im going to take alook at it tonight the problem is it wont start and when you turn the ignition on there is no sound from the fuel pump he has tried changing the fuel pump but still no sound could a relay or fuse be the problem or is there anything else i should check??
    Regular Member Avenged's Avatar
    Liverpool
    ... tell him to scrap it and get a new one!!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Faulty immobiliser..??
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    just beat me to it dan!
    deffo sounds like an immobiliser problem
    Mar 2007
    Grimsby, Lincs.
    Apr 2008
    Liverpool
    Just reading through it will the car turn over if the imobilizer does not work whats putting me off it is even when the imobiliser does no work the fuel pump should still make a noise like its powering up but it does not should it still make a noise
    Regular Member Craig1985's Avatar
    harwich essex
    there is a sensor on flywheel too? is this is faulty is doesnt reckomise engine turning over so wont deliver fuel?
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by Sean-2.2Direct View Post
    Could be a 3rd party immobiliser. A friend of mines Corsa had this issue a while back, it basically cut the power to the whole car when it failed.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I'm not sure if the older mondeos have it but there is sometimes a fuel cut-out switch down next to the passenger footwell. Check the handbook for this. As for the immobiliser there is a red light in the dash. Put the key in and turn it to position 2, the light should come on and then go out in a few seconds. If it flashes the the key may need re-coded. Hope this helps
    Mar 2007
    Grimsby, Lincs.
    mr father in law had a similar snag with his proton.
    the car would tick over, but due the the immobiliser becoming electrically disconnected, the fuel pump would not operate, therefore the car wouldnt start, but it does turn over.
  1. Saw a 57 vec c for £1995 today!!!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 00:49
  2. 2003 03 vectra 1.8ls £1995
    By j1 wyx in forum Cars for sale
    Last Post: 20th July 2010, 07:43
  3. ulstar ralley 1995,lucky escape
    By solorider in forum General Chat
    Last Post: 22nd May 2009, 08:20
  4. problems with 1995 2.0 SRI at idle...
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 17:32
  5. Ford 1300 1995 Engine
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2006, 17:39
