Thread: Rattleing Nose,,,,,,VERY ANOYING!
    Regular Member s0501291's Avatar
    Warrington
    Default Rattleing Nose,,,,,,VERY ANOYING!
    Hi All
    Dont know if anyone else has had this, it could be anything really... Its a rattling nose coming from the passenger side. When im driving along it sounds like near the front passenger seatbelt, B post area,, but could be anything on the passenger door area. its doing my head in. AND to top it off, I got my dad to drive the car whilst I listend from the passenger seat,, and the sound moved from passenger side, to sounding like it was coming from the drivers side door!. Its definatly not engine noise, its from the vibrations of the road,, and its at 30 -40mph cruising speed, which is 90% of my driving,,, like I say,, very annoying!!! Any common offenders to check?
    Any suggestions much apreciated
    Pete
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    First off im probably not going to be much help with this, but I had it too However its now gone, drove me mad. I adjusted the seat belt height, I greased every part of the seat mechanism, cleared out and sorted the glovebox, checked every part of the roof lining, dismantled & assembled the sunglasses holder, checked the passengers cubby hole, I was convinced it was something to do with the seat belt tensioner but literally cleaned out and checked over the whole car, anyway after doing all of the above it went away, unfortunatley I cant say what solved it but one of the above did. You probably want to kill me now
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by s0501291 View Post
    The Missis?
    Regular Member hyperman's Avatar
    pontefract
    i too have a similar rattling noise, sounds like its coming from the passenger side until u sit in that side then it sounnds like its coming from the drivers side! however i know what mine is! it was coming from the centre blanking plate where some models have the sunglasses holder, i took the plate off and the noise went, so i bought a sunglasses holder and hey presto! its still does it....
    May 2008
    Tyneside
    Had an annoying rattle on my sons corsa c. Sounded just like it was coming from inside the door, turned out to be a loose heat deflecter above the exhaust backbox. Worth a look. Theres also one above the main exhaust section. HTH
    Blantyre
    Quote Originally Posted by hagga View Post
    the missis?:d
    lmao
    Regular Member SRimonkey's Avatar
    wednesfield
    my glove box rattles a lot cos its chocka full of junk,so i just crank 2500 watts up loud till i cant hear it no more
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Guys, I had the exact same thing as this and it too was the overhead storage. I had some spare bulbs in one that were rattling ever so slightly. When sitting in the drivers side it seemed to come from the passenger side and vice versa. Took the bulbs out - sorted!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I had this rattle not so long back, sounded like it was coming from inside the car and was driving me mad because I couldn't track it down.....
    http://www.vectra-c.com/forum/showthread.php?t=75511
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    i had the rattle & thought it was somewhere in the Glove box,
    But I've traced it to the fuse extractor in the fuse box next to the glove box
  1. Another anoying problem.
    By portreathbeach in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 08:16
  2. Anoying knocking from rear!
    Last Post: 19th March 2012, 19:58
  3. nose to nose facelift towered!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 09:59
  4. My nose job ...
    By hans_vledder in forum Styling
    Last Post: 27th January 2008, 17:48
  5. Red Nose Day
    By leeandjude in forum General Chat
    Last Post: 17th March 2007, 11:47
