Thread: extended network q warranty
    greenock
    Default extended network q warranty
    ok posted a few days ago saying one on my back brakes was grinding now today both are grinding and i will need new disks and pads
    so its just been normal wear and tear
    are these covered by the extended warranty ?
    Not by the extended Net Q warranty. If the car came with a 12 month Net Q warranty when you got the car then it's covered under that, but after that 12 months if you extend it then it's not covered (discs and pads)
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i brought an extended 1yr network Q warranty when i brought my car @ about 19 month's old and the brakes were covered, this poilicy cost me £99.00 and was a top up type thing to run along side the standard VX manufacturer's warranty....hth
    Midlands Mod Shop - NFFC.
    Leicester
    It's worth checking, sometimes it is covered. It all depends what level Network Q cover you have.
    They should, I've never had any problems making a claim for failed discs which have ripped through the pads (and seems to be quite common on the OE set)
    However, if the pads have worn and destroyed the discs, then the claim will be refused
    Equally, if the pads and/or discs are over 3 years / 30K miles old the claim will also be declined, as that is considered their nominal lifespan
    greenock
    the pads went first my friend thinks
    ok folks thanks for that
  1. extended warranty
    By dazali64 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2009, 16:16
  2. Extended Warranty ????
    By Longtallhowie in forum General Chat
    Last Post: 26th March 2007, 07:29
  3. extended warranty
    By exvectra in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2006, 13:48
  4. Network q extended warantee
    By steveked in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2006, 21:37
  5. Network Q extended warranty
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2006, 22:26
