Thread: oil in engine bay
    wigan
    Default oil in engine bay
    arrived in Holyhead to see smoke coming from front grille,opened the bonnet and there was oil everywhere!.Checked what i think are the breatrher pipes and they were clear,no emulsion.There is another pipe coming from further down the engine block whuch starts off as rubber then goes to pipe,not taken this off yet but not sure what it does?Also wondering if it could be a faulty oil cap? Any idea folks? sorry forgot to mention it's a 1.8 vectra ls on an 04 plate
    WGAF#5
    best thing would be an engine clean and then start looking from there - whilst its covered in oil may be difficult to see - check yr oil level - if its blown that much over the engine bay you would be running low??
    i'm sure someone will be along with a better idea- maybe some piccys?
    hth
    regards
    Dez
    Winteringham
    pics would help locate the problem area
    Full Member spennny's Avatar
    Blantyre
    Oil Filter at the front maybe , if the bay is a mess then there is pressure behind where its leaking from, you would see oil from the cap i would think .
    Hope you get this sorted out & it's not an expensive repair to do ............
    Wales, UK
    Hia, had very similar problem recently, sprayed oil everywhere, covered the cat in oil and the underside all the way to the back seats lol !!!
    It was the oil pressure switch, might be worth a look ???
    Belfast
    If there's the amount of oil coming out of the filler cap that you're describing, then you're in trouble. Most likely pressure switch or filter.
    wigan
    thanks all for your ideas,it doe's appear that tha oil has come from around the oil cap as the main concentration was just above the oil cap and under the cover.Where abouts is the oil pressure switch? sorry for sounding like such a numbty,also have been running the engine and as yet the symtons have not re-appeared
    Wales, UK
    I belive the pressure switch is around about centre - on the front of the block..
    Someone confirm/correct ?
  1. Replies: 5
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
