Results 1 to 10 of 11
Thread: What is P0036 - HO2S Heater Control Circuit (Bank 1 Sensor 2)
    Apr 2008
    Chester
    Default What is P0036 - HO2S Heater Control Circuit (Bank 1 Sensor 2)
    Hi Guys,
    Just read this code from my 1.8 (123bhp) Vectra C 52 reg using a new U480 reader.
    Is this the Lambda sensor that is located in the engine bay that goes through the headshield into the downpipe?
    Similar to this picture: http://www.lambdapower.co.uk/images/...y_lsswap_1.jpg
    What is Bank 1 related to?
    If this is Sensor 2 where/what is sensor 1? and what is the Sensor after the cat?
    Is this the one i need (£58.45)
    http://www.gendan.co.uk/oxygen_lambd...ctra_1.8i.html
    I need to get htis fixed asap.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Banks 1 and 2 is just is a way of differentiating between the banks on 'V' engines. 4 pots will always be called bank 1 (as it only has one bank of cylinders)
    Sensor 2 usually means post cat (so cat performance can be measured), the one in your pic would be sensor 1.
    I don't know where sensor 2 is, as I've never looked for it.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Im not 100% sure but I think that heater banks could be glowplug related.. but im sure someone will correct me if im wrong.. seem to recall a similar problem on an astra works estate and it had new glowplugs fitted..
    Apr 2008
    Chester
    Thanks guys
    The spark plugs (as it is a petrol car) have recently been replaced when i got serviced at the garage.
    So you guys reckon it is pointing at the sensor underneath the car then?
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    pmsl... Doh!! Yeah it won't be glowplug related then!!
    WGAF#5
    generally now have upstream 02 sensor and downsteam 02 sensor
    one in the manifold and one in the pipe
    hth
    regards
    Apr 2008
    Chester
    any idea how difficult sensor 2 is to access, if it was the top one i was going to attempt it myself but unsure if i could easily access sensor 2
    Mileage : 000
    The second sensor might be underneath behind the engine. Most likely on the top of the exhaust.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    HO2S is
    H - Heated
    O2 - Oxygen
    S - Sensor
    and what I wrote earlier is correct.
    You sure about the code?? Could it be P0136?
    Apr 2008
    Chester
    I will double check the code later. I read the code using a U480 scanner, but this is the first time i have used it so i am assuming it is accurate. Any one else used / got one of these scanners?
    It picked up 1 x DTC code.
    Is it worth clearing the code? or am i best keeping keeping it in the memory incase i need to go to a garage?
    cheers
  1. Replies: 5
    Last Post: 3rd January 2013, 21:56
  2. Replies: 3
    Last Post: 13th August 2012, 22:25
  3. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  4. Oxygen Sensor Heater Circuit Voltages?
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:28
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
vectra p0036
vectra c ecn 0036
p0036 opel
dtc p0036 opel location
poo36 heater sensor vauxhall vectra
https:www.vectra-c.comforumshowthread.php77359-What-is-P0036-HO2S-Heater-Control-Circuit-(Bank-1-Sensor-2)page2
opel vectra c p0036
where is bank 1 sensor 2 located vectra c
p0036 vauxhall zafira
p0036 vauxhall vectra c
vectra c temperature sensor location
p0140 o2 sensor circuit no activity detected (bank 1 sensor 2 zafira )
vectra c 2.2 ho2s heater control circuit bank 1 sensor 1 location
p0036 00
vectra c poo36
heater sensor opel vectra 04 bank1
Opel P0036
p0036 opel vectra c
p0036 vectra
vectra heater control unit bank 1 sensor 2
vauxhall p0036
vauxhall omega ecu code P0036
p0036 vectra c
poo36 ho2s heater control circuit bank 1 sensor 2
vectra c cat not ready
