Results 1 to 10 of 17
Thread: M32 Quaife ATB Limited Slip Differential
    Regular Member darko2301's Avatar
    Croatia
    Default M32 Quaife ATB Limited Slip Differential
    I was surfing when i found this pretty interesting stuff on courtenaysport website.
    Quote Originally Posted by CS
    Now available from Courtenay Sport, the Quaife ATB differential for M32 gearboxes. A direct replacement for the standard Vauxhall differential, the Quaife ATB differential transforms your car's performance, making getting the power down onto the road easier, for improved traction and driveability.
    Unlike a conventional plate-style limited slip differential, the ATB diff relies on gears rather than clutch plates for its operation. That means it is much smoother in operation. Because of this, the ATB differential never locks harshly with a set pre-load of wheel slip across the driven axle, like a conventional LSD. Rather, the differential automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree, and never locks. The Quaife ATB differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
    Available now for Astra VXR (Z20LEH), Astra 1.9 CDTi, Astra H 2.0 Turbo (Z20LEL/Z20LER), Astra H 1.6 Turbo (Z16LET), Corsa VXR (Z16LER), Corsa D SRi 1.6 Turbo (Z16LEL)
    as you can see, it suits the 1.9 cdti engine, i believe it can be fitted in vectra too?
    would it be an improvement or wasted money?
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Steve @ LMF sells these aswell, Might be worth pm'ing LMF or emailing them and asking them about it..
    I think that chris (chrisgettings) on here has one fitted to his vectra aswell
    Croatia
    i already started writing an email but i thought i'd ask for opinions here first
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Spoons has one as well. Not too sure if its on his VXR or on the old VXRD
    Croatia
    so, spoons or chris, any comments on product?
    Spoons had/has one on his VXR, and I seem to remember refering to it 'as the car Vauxhall should have built in the first place'...
    spoons
    Guest
    Quote Originally Posted by darko2301 View Post
    PM'd
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by spoons View Post
    PM'd
    well done that man!
    Regular Member PAULMAC77's Avatar
    warrington
    how much do they cost?
    spoons
    Guest
    Quote Originally Posted by Big-Pete View Post
    well done that man!
    Well, as I've attracted a couple more PM's for feedback, I'd better post my findings here as well.
    I have the Quaiffe ATB LSD fitted to the Vectra VXR.
    It hasnt improved my quarter mile times. So its not really a huge benefit in a straight line. I was hoping for better traction off the line, but the benefit is so so small it isnt worth mentioning.
    However, the big benefit, and where its instantly noticeable is going round corners. The ATB LSD 'pulls' you into the apex of the corner. So whereas you normally feel your steering drifting wide as you go round, with the LSD, the steering is being pulled into the corner.
    This can catch you out if your not careful as the car digs in under more power. So its great for medium to high speed cornering .. but you will need to relearn how your car drives under hard acceleration.
    You dont even notice its there otherwise, the car feels totally standard to drive.
    Is it worth it? - yes and no.
    Yes = faster cornering, two wheel grip in the wet, no torque steer, Unit cost = c. £500-600
    No = High fitting costs (£500-£600)
    Steve
  1. Diff / Differential for F17 Gearbox
    By AdeyCorp in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:10
  2. Quaife LSD in GSi
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 30th June 2011, 13:06
  3. Where to find interchange differential
    By zafira in forum Engine & Drivetrain
    Last Post: 1st June 2011, 18:13
  4. Welded Differential...
    By maurauth in forum Comedy & Humour
    Last Post: 23rd February 2010, 02:38
  5. Quaife LSD
    By superstuper in forum Handling & Braking
    Last Post: 1st January 2008, 23:16
